Portsdown 2019
The 2019 Portsdown is significantly different to previous versions in that the system no longer uses the custom built Filter Modulator card which has been replaced with an off the shelf LimeSDR Mini.
The LimeSDR Mini plugs in to the Raspberry Pi USB port, preferably via a powered USB hub and produces an RF outut from ~ 30MHz to 4GHz.
Overall the LimeSDR Mini is similar in cost to the FM board as you no longer need an ADF4351 LO module and an LO filter PCB and is available from the BATC shop https://batc.org.uk/shop/limesdr-mini/
Portsdown 2018
If you would still like an FM board, we suggest you post on the wanted section of the forum - https://forum.batc.org.uk/viewforum.php?f=14 - or blank PCBs for home construction are available here - BATC shop item 10.
All the wiki information on previous version of Portsdown are available here...
Specification
Hardware System Diagram
Here is the latest system diagram. Note that only one of the displays is required; either the 3.5 inch or 7 inch and the digital variable attenuator is only required if you want fine (<3 dB steps) control over your PA drive levels. The Lime Gain control on the Portsdown can be used to set the coarse output level.
Building the system
Portsdown 2019 Software
The Portsdown 2019 uses the same software as later versions of the Portsdown 2018 software and is based on the Rpi Stretch operating system.
Waveshare 3.5 inch screen
To get started, once you have an SD card with the Portsdown 2019 software loaded, simply put the card in the SD slot on the Rpi.
If you have a Waveshare touch screen the Portsdown 2019 software is pre-configured ready to use and no initial configuration is required. Connect the Waveshare 3.5 inch touchscreen (being careful to align the pins correctly) and apply power to the Rpi and the user interface should appear.
From the Main Menu you can set up the output device (LimeSDR Mini, Portsdown Filter-modulator board, DATV Express etc), and all the main transmission parameters. Most of the other settings are on Menu 3, but the defaults will just work initially.
Element 14 7 inch screen or headless operation
However if you do not have a waveshare screen or you wish to enter the system advanced set-up pages you will need to do an initial setup - see this guide for more details: Initial setup 2019
  • Console mode Use this mode to configure your Portsdown and change pre-set configs (such as SR and Freq) used in touch screen buttons.
