Es'hail-2 Ground Station
Revision as of 22:34, 10 February 2019 by G8GTZ (talk | contribs) (→‎Receivers)
The BATC WebSDR & Spectrum Monitor are located at the icon Goonhilly Earth Station in Cornwall (IO70JB).
The equipment is housed in a room dedicated to amateur radio infrastructure in what was the control room for the now defunct GHY2 90 ft dish antennae which was built in 1969.
As well as the Es'hail-2 (now known as Qatar Oscar 100) webSDR and spectrum monitor, the amateur radio facility houses an AMSAT-UK Funcube ground station and an HF Kiwi WebSDR.
Current Status
The RF hardware was installed at Goonhilly Earth Station in August 2018 and installation was completed in January 2019.
The service was launched on 10th February 2019, 4 days before Oscar 100 was commissioned.
Technical Details
Dish
The original 1.2mt dish
RF Front End
A modified Octagon quad LNB is mounted on the dish and locked to 25MHz output from a LeoBodnar GPSDO.
2 coaxes are used to feed separate horizontal & vertical feeds in to the equipment room.
Equipment room
The Qatar Oscar100 equipment shares the dedicated amateur equipment room with an AMSAT-UK Funcube ground station and an HF Kiwi SDR.
Receivers
GPS reference
The GPS reference is a Leo Bodnar unit programmed to produced 10 MHz (for the Airspys) and 25 MHz for the LNB,. The settings for the reference to produce these 2 frequencies were not straightforward (as the 2 outputs on the Leo Bodnar unit need to be linked) but are here for reference:
Host PC
The websdr and spectrum monitor are both hosted on a common PC platform, designed and developed by Phil MoDNY, with the following specification.
PC Hardware
i7-2600 CPU
16GB DDR3 RAM
Intel DQ67SW Motherboard
500GB Samsung 850 EVO SSD
750W Corsair TX Power Supply
PC Software
Ubuntu Server 18.04
Nginx Web Server
airspy_tcp fork (source)
Network
The network connection provided by Goonhilly provides a capability of < 250Mbit/s up and down stream.
The networking infrastructure designed by Phil M0DNY consists of the following:
TBC
