Oscar 100 has an 8MHz wide band transponder dedicated to Digital Amatuer Television.
A typical DATV receive system will consist of the follow:
Dish
To receive the DATV signals you will need at least a 90cms dish and preferebaly 1mt or larger - see this guide as to how to align your dish on the Es'hail-2 satellite: https://wiki.batc.org.uk/images/5/5d/Getting_ready_for_Es%27hail2.pdf
LNB
Just like any consumer satellite system, you will need an LNB at the dish to convert the 10GHz Ku band signals down to L Band which can then be decoded by the satellite receiver. Whilst any modern Ku band satellite LNB will receive the BADR4 signals, it is recommended that you use a Phase Lock Loop LNB to receive the Es'hail-2 amateur signals. This is because the frequency stability of a standard DRO unit will make it difficult to receive the Narrow Band transponder SSB signals and Reduced Bandwidth DATV (RB-TV) signals on the wide band transponder.
DATV receiver
To receive the wide band, horizontally polarised DATV transponder you will need a DATV receiver capable of receiving 741 MHz to 749MHz.
Unfortunately this is outside the normal tuning range of a consumer digital TV Set Top Box (STB) and you will need an additional up converter to shift the IF frequency up to be in the tuning range of the STB at L-band between 950 – 2150MHz. Such converters are available, however there is a USB tuner designed specifically for Amateur TV use which covers down to 143MHz and is suitable to receive Es’hail-2 with no modifications or additional up-converter.
These units are called MiniTiouner and are available from the BATC and other sources and are used with the MiniTiouner software developed by F6DZP to receive and decode the signals. See https://wiki.batc.org.uk/MiniTioune for more details.
The other reason why MiniTioune is the preferred solution to receive the DATV transponder is that most amateur TV transmissions are using Reduced Bandwidth DATV (RB-TV) with a bandwidth below 1 MHz. A standard consumer STB will not receive these RB-TV signals but MiniTiouner has been designed to receive RB-TV signals with less than 100 KHz bandwidth. Note - there is a DATV beacon transmission running at 2Ms which can be received using a standard DVB-S2 receiver and appropriate up converter.
Note that the DATV receiver will need to be capable of providing 18v DC to the LNB to select horizontal polarisation required for the wide band transponder.
Setting up your receiver
You will find it a lot easier to tune to the DATV signals on Oscar100 if you put your LNB offset in to your receiver rather than try to enter the IF frequency such as 739.5MHz directly.
Most LNBs have a 9750MHz local oscillator - when 9750 is put in to your receiver offset (on MiniTiouner it is the white box directly below the frequency box) you can then just enter the 10GHz freq dshown on the spectrum display directly in to your receiver.
Tuning to the signals
Once you have the system set up and you have successfully received the DATV beacon on 10492MHz 2Ms DVB-S2 you will be ready to receive DATV signals.
Typical receive results
Oscar 100 DATV beacon - 10492MHz, DVB-S2 2Ms
Dish size MER rx'd Comments
1.2mt ? MiniTiouner
SR Dish size MER
Example Example Example
