Streaming directly from MiniTiouner
Revision as of 11:34, 18 February 2019 by G8GTZ (talk | contribs) (→Install ffmpeg)
Using the UDP output and an ffmpeg batch file it is possible to stream directly from MiniTionuer to the BATC streamer.
Note: this requires a higher spec PC and drop outs and audio problems on higher bit rates are likely to be processor overloading. It also requires some knowledge and is therefore not recommended for beginners!
Configuring MiniTionuer
  • configure MInTiouner to receive signals.
  • Edit your minitioune.ini file (found in the same directory as all MiniTiouner programs) so that the UDP output is only on 127.0.0.1 and port 1234 - it should look like this:
; adresse UDP / UDP address
[UDP]
;AddrUDP=230.0.0.1
AddrUDP=127.0.0.1
Port=1234
Install ffmpeg
Now create the windows batch file which will control ffmpeg. Copy the following text in to a text editor (windows note pad etc):
SET ffmpeg="C:\Users\fred\Desktop\ffmpeg\ffmpeg-4.1-win32-static\bin\ffmpeg.exe"
SET stream=g8abc-derjky
:loop
 %ffmpeg% -i udp://127.0.0.1:1234?timeout=100000000 -c:a libmp3lame -b:a 64k -c:v libx264 -b:v 600k -preset fast -f flv rtmp://rtmp.batc.org.uk/live/%stream%
goto loop
You MUST change the text highlighted in black: Set FFMPEG=" should have the path to the ffmpeg.exe file on your computer. SET stream= Enter your BATC stream name-stream key
Save the file in the ffmpeg directory and if needed create a shortcut to your desk top.
