Revision as of 18:09, 18 February 2019 by G8GTZ (talk | contribs) (→‎SDRs)
Dish
LNB
Just like any consumer satellite system, you will need an LNB at the dish to convert the 10GHz Ku band signals down to L Band which can then be decoded by the satellite receiver. Whilst any modern Ku band satellite LNB will receive the BADR4 signals, it is recommended that you use a Phase Lock Loop LNB to receive the Es'hail-2 amateur signals. This is because the frequency stability of a standard DRO unit will make it difficult to receive the Narrow Band transponder SSB signals and Reduced Bandwidth DATV (RB-TV) signals on the wide band transponder.
DATV receivers
Note that the DATV receiver will need to be capable of providing 18v DC to the LNB to select horizontal polarisation required for the wide band transponder.
What receiver to use
There are a couple of options you can use - however as the frequencies in use are not standard satellite frequencies and the bit rates we use for ATV are lower than commercial satellites the choice is limited.
Standard satellite receivers
To receive the wide band, horizontally polarised DATV transponder you will need a DATV receiver capable of receiving 741 MHz to 749MHz.
Unfortunately this is outside the normal tuning range of a consumer digital TV Set Top Box (STB) and you will need an additional up converter to shift the IF frequency up to be in the tuning range of the STB at L-band between 950 – 2150MHz. Such converters are available, however there is a USB tuner designed specifically for Amateur TV use which covers down to 143MHz and is suitable to receive Es’hail-2 with no modifications or additional up-converter.
MiniTiouner
The preferred solution to receive DATV signals is are called MiniTiouner and are available from the BATC and other sources and are used with the MiniTiouner software developed by F6DZP to receive and decode the signals. See https://wiki.batc.org.uk/MiniTioune for more details.
The other reason why MiniTioune is the preferred solution to receive the DATV transponder is that most amateur TV transmissions are using Reduced Bandwidth DATV (RB-TV) with a bandwidth below 1 MHz. A standard consumer STB will not receive these RB-TV signals but MiniTiouner has been designed to receive RB-TV signals with less than 100 KHz bandwidth. Note - there is a DATV beacon transmission running at 2Ms which can be received using a standard DVB-S2 receiver and appropriate up converter.
SDRs
Standard SDRs will not receive DATV signals - there are 2 programs for the advanced user which may work at some symbol rates:
Setting up your receiver
Tuning to the signals
Typical receive results
Dish size MER rx'd Comments
1.8m 10dB
1.2m 8dB
1m 6dB
80cm 5dB
SR Dish size MER
Example Example Example
