Dish
LNB
Whilst any modern Ku band satellite LNB will receive the Oscar 100 signals, it is recommended that you use a Phase Lock Loop LNB. This is because the frequency stability of a standard DRO unit will make it difficult to receive the Narrow Band transponder SSB signals and Reduced Bandwidth DATV (RB-TV) signals on the wide band transponder.
Note that the DATV receiver will need to be capable of providing 18v DC to the LNB to select horizontal polarisation required for the wide band transponder or position the LNB 90 degrees offset and fed 12v.
What receiver to use
There are a couple of options you can use - however as the frequencies in use are not standard satellite frequencies and the bit rates we use for ATV are lower than commercial satellites, the choice is limited.
Standard satellite receivers
To receive the wide band, horizontally polarised DATV transponder you will need a DATV receiver capable of receiving 741 MHz to 749MHz. Unfortunately this is outside the normal tuning range of a consumer digital TV Set Top Box (STB).
You will either need an additional up converter to shift the IF frequency up to be in the tuning range of the STB at L-band between 950 – 2150MHz or modify your LNB to produce an IF output above 950MHz.
Whilst you will be able to receive the DATV beacon signal on 10,492MHz which is transmitted using 2 Msymbols/sec, you will not be able to use most (95%) of consumer STB's to receive the Reduced bandwidth (RB-TV) signals which are typically 333Ks on Oscar 100.
MiniTiouner
However there is a USB tuner designed specifically for Amateur TV use which natively covers 143MHz to 2450Mhz and is suitable to receive Es’hail-2 and a number of amateur bands with no modifications or additional up-converter.
The other reason why MiniTioune is the preferred solution to receive the DATV transponder is that most amateur TV transmissions are using Reduced Bandwidth DATV (RB-TV) with a bandwidth below 1 MHz. A standard consumer STB will not receive these RB-TV signals but MiniTiouner has been designed to receive RB-TV signals with less than 100 KHz bandwidth. Note - there is a DATV beacon transmission running on Oscar 100 at 2Ms which can be received using a standard DVB-S2 receiver and appropriate up converter.
SDRs
Standard SDR software and hardware will not receive DATV signals - there are 2 programs for the advanced user which may work at some symbol rates:
Setting up your receiver
Tuning to the signals
Typical receive results
Dish size MER rx'd Comments
1.8m 10dB
1.2m 8dB
1m 6dB
80cm 5dB
SR Dish size MER
Example Example Example
