The transponder spectrum can be monitored using the online spectrum monitor: https://eshail.batc.org.uk/wb/
However, to receive and decode the signals you will need to set up your own receiving station
Dish
LNB
Whilst any modern Ku band satellite LNB will receive the Oscar 100 signals, it is recommended that you use a Phase Lock Loop LNB. This is because the frequency stability of a standard DRO unit will make it difficult to receive the Narrow Band transponder SSB signals and Reduced Bandwidth DATV (RB-TV) signals on the wide band transponder.
LNB power
All satellite receivers can do this - select LNB voltage in set up - and when using MiniTiouner this can be done by using a step up regulator from 12v (plenty on ebay) and feeding 18v in to F2 and put J3 and J4 links in to fed the selected LNB. https://wiki.batc.org.uk/images/6/6d/SERIF.pdf
What receiver to use
There are a couple of options you can use - however as the frequencies in use are not standard satellite frequencies and the bit rates we use for ATV are lower than commercial satellites, the choice is limited.
Standard satellite receivers
To receive the wide band, horizontally polarised DATV transponder you will need a DATV receiver capable of receiving 741 MHz to 749MHz. Unfortunately this is outside the normal tuning range of a consumer digital TV Set Top Box (STB).
You will either need an additional up converter to shift the IF frequency up to be in the tuning range of the STB at L-band between 950 – 2150MHz - an SUP2400 converter previously sold by BATC will work - or you modify your LNB to produce an IF output above 950MHz.
Once you have an upconverter or modified LNB you will be able to use a DVBS2 (HD) receiver to receive the DATV beacon signal on 10,492MHz which is transmitted using DVBS2 Msymbols/sec.
However, you will NOT be able to use most (95%) of consumer STB's to receive the Reduced bandwidth (RB-TV) signals which are typically 333Ks on Oscar 100.
MiniTiouner
However, there is a USB tuner designed specifically for Amateur TV use which natively covers 143MHz to 2450Mhz and is suitable to receive Es’hail-2 and a number of amateur bands with no modifications or additional up-converter.
SDRs
Setting up your receiver
Tuning to the signals
Typical receive results
Dish size MER rx'd Comments
1.8m 10dB
1.2m 8dB
1m 6dB
80cm 5dB
SR Dish size MER
Example Example Example
