8-Band RF Output Switch
For those of you who want to drive Microwave transverters from your Portsdown or need a higher drive level, the team have developed an 8-Band RF output switch that includes an RF amplifier.
It is capable of amplifying the variable level from the Filter Modulator board / Lime SDR up to 10 dBm and switching it to separate external amplifiers for the 70, 144, 437, 1255 bands and up to 4 transverters for the higher bands. One of the 4 transverter output can also be used for 2300 / 2400 MHz - see mods below to maintain output level.
PCBs and the control PIC are available from the BATC Shop.
Version 2.2 PCBs
The Current PCBs from the BATC Shop are Version 2.2. The previous version, V2.1 requires 2 minor corrections during construction.
The current batch of PCBs from the BATC Shop are version 2.2, which have this fault corrected. The circuit for Version 2.1 and 2.2 PCBs is here: Media:8 BAND RF SWITCH V2-1 SCH.pdf.
Lime SDR
When used with the Lime SDR, Dave G8GKQ recommended changes to the input attenutor in his article in CQ-TV 262 to improve performance at 2.4GHz. C16 changes to 1pF and R5 becomes a Zero Ohms link.
All the parts in the attenuator are 0603 chip sized this V2.3 arrangement is in the revised parts list.
V2.3 for Lime Mini SDR service and underside showing wire link. Assembled by David M0YDH
Version 1 PCBs
The initial design was as shown above - the first batch of boards will be supplied in this form. The initial (V1.0) circuit is here: Media:8 BAND RF SWITCH V1-0 SCH.pdf. The first board layout is here: Media:8_BAND_RF_SWITCH_V2.2_PARTS.xls.
The original parts list and those for V2.2 Portsdown Filter Modulator and V2.3 Lime Mini SDR and has only been checked against the DigiKey Part Numbers, are here: File:8_BAND_RF_SWITCH_V2.2_PARTS.xls. This parts list does include components for the input attenuator for each type of modulator on seperate tabs.
- Cut the track on the underside between the output of the voltage regulator and the link point marked 5VA.
- Replace the 7805 with a 7808 regulator (for 8 volts) and wire a 30 ohm resistor between the regulator output and the the point marked 5VB. Note that the resistor will need to dissipate 300mW (it passes 100mA), so 3 1/8 watt 10 ohm resistors in series might be easiest.
- Wire a new 78L05 regulator on the underside of the board with its input from the 12V supply and its output to the point marked 5VA.
- The input attenuator should be set up with R1=R2=68 ohms, and R3=220 ohms. To get the full 10 dBm output on 1255 MHz, add a series combination of 68 ohms and 2.7 pf across R3. The first batch of PCBs do not have pads for the extra capacitor and resistor.
Usage and Performance
The 8-way switch is intended to be used in association with the digital attenuator described here https://wiki.batc.org.uk/Output_Attenuator .
Typical system output levels with the digital attenuator connected to the output of the filter modulator board, and followed by the 8-way switch are shown below. Output levels and shoulder levels with the attenuator set to 0 dB and 3 dB are included.
Freq | Level @0dB Atten | Shoulders | Level @-3dB | Shoulders |
71 | +10 dBm | -45 dB | +7 dBm | -50 dB |
146 | +12 dBm | -45 dB | +9 dBm | -50 dB |
437 | +14.5 dBm | -45 dB | +11.5 dBm | -50 dB |
1255 | +11 dBm | -45 dB | +8 dBm | -45 dB |
