Using LimeSDR with Portsdown
The Portsdown 2019 software supports the LimeSDR Mini and the LimeSDR USB.
With the Portsdown Filter Modulator board being discontinued, the LimeSDR Mini will become the standard modulator for use with the Portsdown system and is available for purchase in the BATC members shop. More details on the LimeSDR Mini can be found here LimeSDR Mini Information.
Setting up the system
Hardware Installation
The BATC 8-band PTT drive and RF switching boards can be used with the Lime to provide band switching - see below for details on the GPIO port connections.
Installing the Lime Software
The LimeSuite software version 19.01.0 (Interface version v2019.1.0, Binary Interface 19.01-1) is loaded as part of the normal Portsdown build and update process. This may not be the latest version, but is compatible with other components of the Portsdown software and the latest DATV Express version.
Once installed, you can use your Portsdown to update the firmware and gateware on your LimeSDR (Mini or USB) to the compatible version.
Lime Configuration Menu
The "Lime Config" Menu is selected from Menu 3. Selecting "LimeUtil Info" displays the current version of LimeSuite.
The "Update Lime FW" button updates the Lime SDR firmware and gateware to the appropriate version for the installed LimeSuite. For Portsdown software versions 201903250 and later, the correct version is shown below. You should see the same screen after selecting "Lime FW Info".
The Lime firmware/gateware version that works with the Portsdown is also compatible with DATV Express versions V1.25lp12 and later.
BATC Shop LimeSDR Minis
The LimeSDR Minis purchased from the BATC shop are hardware version 1.2. Those purchased before 14 January 2019 will have firmware 1.26 loaded. Those purchased after 14 January 2019 will have the latest firmware at the time of sale loaded
If you do not use the correct firmware, the transmitted spectrum will not be as clean. If you are unable to upgrade due to apparent problems with the Portsdown/LimeSDR combination, please report the details on the BATC forum.
Note that if you use a Windows PC or a different Linux build to upgrade the firmware to beyond 1.29, you can roll it back to the correct version for the Portsdown by selecting "Force Lime FW" on the touchscreen menu.
Basic Test
You can run a basic test on your LimeSDR Mini, by pressing the "Lime Report" button. Note that this test generates RF output and leaves the LimeSDR Mini generating a carrier on 1095 MHz at about -25 dBm.
First power tests with Lime Mini SDR Portsdown at M0YDH
Transmitting
Limitations
The BATC 4-band and 8-band PTT drive and RF switching boards can be used with the LimeSDR to provide multiband RF and PTT steering. They can remain connected to the RPi GPIO using the standard Portsdown GPIO interface board or (if you are prepared to accept the risk of damaging your LimeSDR Mini) connected to the Lime FPGA GPIO.
The LimeSDR Mini GPIOs 0, 1 and 2 give the same signals as the RPi Band LSB, NSB and MSB. GPIO 7 gives the PTT signal. These can be taken from J5 on the LimeSDR Mini https://wiki.myriadrf.org/LimeSDR-Mini_v1.1_hardware_description or J18 on the LimeSDR USB http://wiki.myriadrf.org/LimeSDR-USB_hardware_description. The pin connections on the LimeSDR USB are different from those on the LimeSDR Mini. Note that these outputs are not buffered and if damaged could prevent the LimeSDR from working again. Our advice is the use the RPi GPIOs.
System Diagram
Acknowledgements
