Equipment Description
Revision as of 14:08, 9 September 2016 by G8GKQ (talk | contribs)
The BATC Event Streaming Equipment consists of:
2 Cameras
HDMI to SDI Converters
Blackmagic ATEM Television Studio
PC with Blackmagic Intensity Pro HDMI interface card and BD-ROM drive
Cyclone HDMI Media Player
Sennheiser Radio mic Receiver
TP-Link Router
The Blackmagic ATEM Television Studio is a 1U rack-mount unit with 4 HDMI Inputs and 4 SDI inputs controlled by the PC
The PC is based on an Asus H1101 Plus D3 Motherboard with an Intel I3-6100 3.7 GHz processor and 8 GB of RAM. The OS is intalled on a 64 GB AGILITY 3 SSD, and there are 2 ST30064 500 GB HDs for storing recordings. It runs Windows 7 Professional, and the following applications:
ATEM Television Studio Software Control Version 6.9
Blackmagic Desktop Video Utility Version 10.7
Adobe Flash Media Live Encoder 3.2
MX Light V2.4 H264 Pro Recorder
VLC Version 2.2.4
vMix Version 17.0.107
Licences for Windows 7 and MX Light are held on behalf of the club by G8GTZ. Notes from the last PC re-build
Set-up
The PC and the ATEM are connected to the LAN (192.168.33.xxx) created by the TP-Link Router. The WAN port on the router is connected to an Internet connection if streaming is required. A USB lead is run from the ATEM to the PC to allow the IP address of the ATEM to be set if a change is required (it needs to be manually set, but does have non-volatile memory). The ATEM is controlled through the ATEM control application on the PC, and the inputs, preview and program are displayed on an HDMI display connected directly to the ATEM.
The HDMI output of the ATEM is connected to the Blackmagic capture card in the PC. Note that all HDMI on the system must be configured to 1080i 25 fps. No other setting works.
If Flash Media Live Encoder is to be used for streaming, the following settings work well with the new BATC Streaming Server:
Device: Blackmagic WDM Capture
Format: H264
Frame Rate: 25.00 fps
Input Size: 1920x1080, tick Maintain Aspect Ratio
Bit Rate: 800 Kpbs Output Size 1280x720
Select the Advanced Encoder Settings (the spanner next to H264) and select:
Profile: Main
Level: 3.1 (note level 4 is required for 1920x1080 streaming)
Keyframe Frequency: 5 Seconds
For the new streamer, the FMS URL is currently rtmp://beta/batc.tv/event. Enter the stream code (password) in the Stream: box.
For the old streamer, the FMS URL is rtmp://fms.batc.tv/live/callsign. Your callsign is also entered in the Stream: box.
vMix can also be used for streaming:
Video Bit Rate: 800, Encode Size: 1280x720, Audio Bit Rate: 96
Profile: Main, Level: 3.1, Present: slow, Keyframe frequency: 5 seconds. Threads: 4, Network buffer: 10, Audio Format: AAC.
Streaming Destination: Custom RTMP Server, URL: rtmp:// beta.batc.tv/event/, Name or key: stream code/password
Input size: 1280x720, Frame Rate: 25, Quality: H264 720p 800kbps AAC 96kbps, Application FFMPEG.
Normal Set-up
In normal operation, the 2 cameras output HDMI to HDMI-SDI Converters, and SDI is run over 75 ohm cables back to the mixer/streaming desk. Any projector video is also converted to SDI and routed back to the desk. Audio handling is venue dependent.
Dave, G8GKQ, 8 Sep 16.
