IARU ATV contest
Update for 2020
The IARU Region 1 ATV Contest will go ahead on the weekend of 13/14 June. However, due the COVID-19 crisis not all participants will be able to reach their portable sites, and some may feel that they are at a disadvantage in only being able to operate from home due to National restrictions.
To address these concerns, the contest will be run with 2 sections:
Section 1 will be for participants operating from their registered home QTH. No change of operating location will be permitted during the contest for entries in this Section.
Section 2 will be for participants operating away from their registered home QTH at any time during the contest. So, even if you operate from home on one day and a portable location on the second day, if you want to add the scores under the rover rule, you must enter Section 2.
Please use the normal entry spreadsheet https://wiki.batc.org.uk/images/d/d5/ATV-contest-log-callsign-20190608.xls and state in the address box whether you are entering Section 1 or Section 2. The latest spreadsheet has a drop-down box for this selection.
Apart from this change, the normal rules will apply. These can be found at http://www.iaru-r1.org/wp-content/uploads/2019/08/ATV-Contest-rules.pdf
Entries should be submitted to your National Coordinator and then passed to me. I will accept entries direct on the e-mail address atv@iaru-r1.org if you are unable to contact your national coordinator.
Please pass this e-mail on to any prospective participants – just for 2 days, we need to get people off of QO-100 and onto the other bands!
Dave, G8GKQ, IARU Region 1 ATV Contest Coordinator.
Who can enter?
What Bands are in Use?
The IARU region 1 ATV Contest includes all harmonised amateur bands above 400 MHz.
Note: Only the UK has the 71 and 146MHz bands and so are not included in the IARU ATV contest.
Signal reports
Time of contest
Submitting an entry
While the important thing is that you get "on the air" at sometime over the weekend, it would be great if you also took the time to submit an entry, even if it is only for a single 5km QSO across town using the 5665MHz drone equipment you just got working! That way we can show to Ofcom and other users that there is real activity on the ATV bands and also so the UK can have highest number of entries in the contest!
Ideally you will submit an entry on the official Excel Spreadsheet which you can download from here Media:ATV-contest-log-callsign-20190608.xls or here (the same file, different name) Media:ATV-contest-log-UK-V4a-2020.xls
Alternatively, simply email in a list of your contacts including times, frequencies, callsigns, locators and numbers sent and received to contests@batc.tv.
Contact scoring
  • For contacts on the 71 and 146 MHz bands: 2 points/kilometre (BATC Contest only)
Previous year's results
2018 contest results
UK stations won both the 24GHz and 76 GHz sections and Rob M0DTS was the highest placed UK station.
And a full list of the UK results can be found here.
2017 contest results
The number of stations entering the contest is increasing each year:
2014 = 33
2015 = 42
2016 = 52
2017 = 95
2018 = 100
Certificates
More information
