Ryde Receiver
The BATC Ryde receiver is a stand-alone receiver for Digital Amateur TV with similar functionality to a consumer Set Top Box (STB) but with a "point and shoot" interface - simply enter frequency and SR and the Ryde will look for DATV signals without the need to enter Bouquets, transponders or scan across a range of frequencies.
Project history and status
Ryde Hardware
The first version of Ryde is based around a Raspberry Pi 4 and the BATC MiniTiouner V2 PCB connected via USB. A single PCB may be developed in future removing the need for the USB interface.
The hardware, including details on the RPi GPIO connections needed, are described on this page: Ryde Hardware.
IR remote control
Ryde Software
The easiest way to install the Ryde software is to build an SD Card and then install the software using the instructions here: BATC GitHub Ryde Build Page. The process will be familiar to anyone who has built a Portsdown SD Card.
Ryde repeater receiver
Outline specification
Code base
Functionality
Network capability
