Portsdown 4
Revision as of 11:18, 15 August 2020 by G8GTZ (talk | contribs) (→FAQ)
No other models of Raspberry Pi or touchscreen are planned to be supported in the near future so please don't ask.
Capabilities
The software build is also compatible with the Langstone Microwave transceiver software, which can be loaded by from touchscreen selections (menu 2) AFTER the Portsdown software has been installed. To operate, the Langstone software needs a Pluto to be connected by USB, and a compatible USB Audio dongle.
The build is on GitHub at https://github.com/BritishAmateurTelevisionClub/portsdown4
FAQ
More information
For early release information see https://forum.batc.org.uk/viewtopic.php?f=103&t=6804
