Ryde Receiver
Revision as of 11:37, 22 August 2020 by G8GTZ (talk | contribs) (→Ryde Software)
The BATC Ryde receiver is a stand-alone receiver for Digital Amateur TV with similar functionality to a consumer Set Top Box (STB) but with a "point and shoot" interface - simply enter frequency and SR and the Ryde will look for DATV signals without the need to enter Bouquets, transponders or scan across a range of frequencies.
Project history and status
Ryde Hardware
The hardware, including details on the RPi GPIO connections needed, are described on this page: Ryde Hardware.
Version 1
Version 2
A single PCB is in development removing the need for the USB interface. This will be a standalone alone unit with the Rpi mounted on the motherboard but will require users to buy a complete new set of componets including Serit tuner.
IR remote control
Ryde Software
  • LongMynd. A specific version of LongMynd is used to control the MiniTiouner.
  • RydePlayer. RydePlayer controls LongMynd, responds to remote control commands, manages the on-screen menus and controls the VLC video player.
  • Pydispmanx. Pydispmanx is a utility to manage the layers (overlays) on the display.
  • Ryde-Build. Ryde-build provides an installer, updater, console menu and currently manages selection of remote controls and display output.
The easiest way to install the Ryde software is to build an SD Card and then install the software using the instructions here: BATC GitHub Ryde Build Page. The process will be familiar to anyone who has built a Portsdown SD Card.
Ryde repeater receiver
Outline specification
Code base
Functionality
Network capability
