Portsdown 4
Revision as of 17:21, 26 August 2020 by G8GKQ (talk | contribs)
The Portsdown 4 system has been specifically designed to be used with the Raspberry Pi 4 and the official Raspberry Pi 7 inch touchscreen. It will drive a LimeSDR (tested with the Mini, but probably Lime SDR USB as well), the DATV Express board (DVB-S only) and, as an experimental capability, the Pluto SDR.
No other models of Raspberry Pi or touchscreen are planned to be supported in the near future so please don't ask.
Capabilities
The software build is also compatible with the Langstone Microwave transceiver software, which can be loaded by from touchscreen selections (menu 2) AFTER the Portsdown software has been installed. To operate, the Langstone software needs a Pluto to be connected by USB, and a compatible USB Audio dongle.
The build is on GitHub at https://github.com/BritishAmateurTelevisionClub/portsdown4
Pluto Capabilities
The Pluto mode is experimental at present and is described here Portsdown 4 Pluto.
FAQ
cd /home/pi
chmod +x /home/pi/update.sh
./update.sh
More information
For early release information see https://forum.batc.org.uk/viewtopic.php?f=103&t=6804
