Ryde Receiver
Project history and status
Ryde Hardware
The Ryde rxr is simple to construct and is built from a standard Raspberry Pi4 and standard MiniTiouner USB receiver hardware. Full hardware details are described on this page: Ryde Hardware.
Version 1
Version 2
IR remote control
Ryde Software
The currently the only way to install the Ryde software is to build an SD Card and then install the software using the instructions here: BATC GitHub Ryde Build Page. The process will be familiar to anyone who has built a Portsdown SD Card.
Please read this information about the Ryde Software.
Ryde repeater receiver
Outline specification
Code base
Functionality
Network capability
