Es'hail-2 Ground Station
The equipment is housed in a room dedicated to amateur radio infrastructure in the workshops building for the now defunct GHY2 90 ft dish antennae, built in 1969. The station currently houses:
- Qatar Oscar 100 WebSDR
- Qatar Oscar 100 pectrum monitor,
- AMSAT-UK Funcube ground station
- The Goonhilly VHF websdr https://vhf-goonhilly.batc.org.uk/
- Kiwi HF WebSDR with GPS TDOA.
RF System
Dish
RF Front End
Receivers
GPS reference
Computer System
- Intel i7-2600 CPU
- 16GB DDR3 RAM
- Intel DQ67SW Motherboard
- 500GB Samsung 850 EVO SSD
- Ubuntu Server 18.04
- Nginx Web Server & Reverse Proxy (github-webpages)
- Narrowband resampler 2.5MS -> 512Ks (github)
- Narrowband WebSDR by PA3FWM (homepage, github-configuration)
- Wideband Transponder FFT Spectrum Server (github)
- Chat Server (github)
Networking
Goonhilly Earth Station has 2x diverse redundant 10Gb links into London Datacenters through Next Connex. They have been kind enough to give us a dedicated IP address and access to >300Mb/s of up & down bandwidth for use by the station.
A high-bandwidth Leo Bodnar NTP Server provides NTP service to the station & the worldwide NTP Pool. Stats and graphs of this service can be viewed at https://eshail.batc.org.uk/ntp/
Wideband monitor
To log in, type the following in to the box at the bottom of the chat (replacing "my name" with your real name or callsign) and press return:
/nick my name
For example:
/nick G8ABC_Fred
You will get a confirmation message that your name has changed and the text in the box changes to "Type a message here and press enter" - your name also appears in the list on the right handside of the page.
Narrow band SDR
