Portsdown 4
  • Raspberry Pi4 2Gb model
  • 7" touch screen
  • 16Gb SD card
  • Adalm Pluto
This will give you a basic DATV transmit system from 70MHz to 6GHz and can be easily upgraded to include the Langstone microwave NB transceiver! With the addition of a MiniTiouner USB receiver [[1]], you will have a full spec DATV transceiver.
Capabilities
  • Control of a Pluto, DATV Express, ADF4351 and Elcom Microwave Source using the Portsdown 4 Signal Generator.
Portsdown 4 GPIO connections
The other changed pin is the LE line for the ADF4351 (was on 27, now pin 33) which is only used if you are using an ADF4351 for the Portsdown Signal Generator.  So, generally no need to worry about this one.
Powering the Pluto
Pluto Capabilities
FAQ
cd /home/pi
chmod +x /home/pi/update.sh
./update.sh
More information
