New builders are recommended to build a Portsdown 4 which, when used with a Adalm Pluto, is integrated with the Langstone Microwave transceiver software enabling an advanced multimode narrow band and DATV transceiver covering 70Mhz to 6GHz for under £350.
The project, which was featured in the June 2017 issue of the RSGB's Radcom magazine, involves some basic construction and is based around a Raspberry Pi with a touchscreen and uses a LimeSDR Mini - before January 2019 the Portsdown used a custom filter modulator card and external local oscillator.
System overview
Touch screen control
Depending on version (see below) the output from the RPi is connected to one of the following units. A BATC Filter Modulator board, LimeSDR Mini or an Adalm Pluto, which modulates the RF carrier and produces the DVB-S or DVB-S2 DATV signal.
Audio and video inputs
Portsdown DATV receiver
On Portsdown 2020 and Portsdown 4, if you plug your MiniTuioner hardware into the RPi USB port and select "Rx" on the top level menu, you will have access to a fully functional DATV receiver.
The received signal is displayed on the 7" touch screen but is also available as a UDP output on the network enabling it to be viewed on a larger PC using VLC or a similar software.
Portsdown Evolution
Portsdown 2018 Classic
Portsdown 2019 Stretch
Portsdown 2020 Buster
The current in-use version of the Portsdown is Buster 2020 - Portsdown 2020. This introduces support for the LimeDVB firmware on the LimeSDR Mini and also supports the use of standard firmware on the LimeSDR USB and the LimeNET Micro.
Portsdown 4
The latest version of the Portsdown is the Portsdown 4 - Portsdown 4. This uses the Raspios Buster operating system on a Raspberry Pi 4 with a 7 inch screen and a LimeSDR. Unlike the previous version changes it does not maintain hardware compatibility with the classic (filter-modulator) Portsdown.
New builders are recommended to build a Portsdown 4 which, when used with a Adalm Pluto, is integrated with the Langstone Microwave transceiver software enabling an advanced multimode narrowband and DATV transceiver covering 70Mhz to 6GHz for under £500.
