Portsdown 4
The Portsdown 4 system has been specifically designed to be used with the Raspberry Pi 4 and the official Raspberry Pi 7 inch touchscreen. It will drive a Pluto SDR or the LimeSDR and the DATV Express board (DVB-S only).
  • Raspberry Pi4 2GB model
  • 7" touch screen
  • 8, 16 or 32 GB SD card
  • Adalm Pluto or Lime SDRmini
This will give you a basic DATV transmit system from 70 MHz to 3.4 GHz and, if you are using the Pluto, can be easily upgraded to include the Langstone microwave NB transceiver!
With the addition of a MiniTiouner USB receiver [[1]], you will have a full spec DVB-S/S2 DATV transceiver. DVB-T transmit capability is now included, and the Knucker Tuner can be used with Portsdown 4 for DVB-T receive.
Capabilities
The Portsdown 4 has the following transmit and receive capabilities:
  • DVB-S, DVB-S2 and DVB-T (H264 only) transmissions from a Pluto SDR connected by USB
  • DVB-S, DVB-S2 and DVB-T (MPEG-2 and H264) transmissions from a LimeSDR Mini or LimeSDR USB
  • Streaming to the BATC Streamer using the Raspberry Pi Camera or EasyCap composite video capture device as a source
When a MiniTiouner USB receiver is connected via USB:
  • Reception and display of DVB-S and DVB-S2 (MPEG-2, H264 and H265) signals
When a BATC Knucker USB tuner connected by USB:
  • Reception and display of DVB-T and DVB-T2 (MPEG-2, H264 and H265) signals
Portsdown test and alignment aids
  • Basic spectrum display of band occupancy using the "Portsdown Band Viewer" - requires a LimeSDR Mini to be connected.
Portsdown 4 GPIO connections
The other changed pin is the LE line for the ADF4351 (was on 27, now pin 33) which is only used if you are using an ADF4351 for the Portsdown Signal Generator.  So, generally no need to worry about this one. This isn't true if your Portsdown has an attenuator card fitted! Move the LE wire with its 1 K ohm resistor to the Q terminal.
Powering the Pluto
You MUST start with a fresh build of Raspios Buster Lite (NOT the older Raspbian) on an SD Card of 8 GB or greater, so you will need to rebuild any previous Langstone or Portsdown A27 card.
Pluto Capabilities
FAQ
cd /home/pi
chmod +x /home/pi/update.sh
./update.sh
  • I have built my Portsdown 4 but the screen is upside down. How can I get it the right way up?
More information
