Getting Started
One of the aims of the BATC is to help members get on the air. To do this the BATC has come up with the Portsdown project which is easy enough for most people to successfully build at home and gives you the basics of a very credible DATV transceiver (It can also be upgraded to receive DATV)
Hundreds of these have been built by amateurs around the world and part of its success is down to the club prescribing the key components/design (and you sticking to them...) and following simple build instructions.
Yes I know radio amateurs (me included) like to tinker and experiment but at this stage it really helps our volunteers help you. That way, if there are any problems, it's easy to offer support via the BATC forum. And if you still can't get it going bring it along to one of our Portsdown clinics which are held at most rallies the BATC attends.
The best way forward
We often get asked how do I start to receive or transmit ATV?
Really easy ATV
Probably the easiest way to get on the air with ATV is by using drone FM transmitter/receiver modules - take a look at this page which shows you how to join in the fun on 5.6GHz for around £20.
This is enough to get good quality pictures over several miles over line-of-sight paths with simple aerials - though with a better aerial and a good portable location at both ends of the link - it is possible to work hundreds of miles during favourable atmospheric conditions.
This BATC forum post by one of our members shows what distances can be worked, and fun can be had, using very basic equipment: https://forum.batc.org.uk/viewtopic.php?f=75&t=5437
The BATC is running a ladder contest to encourage activity using this simple equipment - see https://batc.org.uk/contests/6cm-ladder/
Receiving DATV
The easiest way to receive DATV signals is to build a BATC designed Ryde Set-top top box based on a Raspberry Pi4 (you can buy a pre-programmed SD card from our shop and the Minitiouner USB receiver PCB. The Ryde can be controlled using a any Infra Red remote control and can drive either an HDMI or composite video monitor.
See this wiki page for more details on the Ryde receiver.
The MiniTiouner PCB and other "hard-to-get" components can be bought from the BATC shop https://batc.org.uk/category/usb-receivers/ - the remainder are standard leaded (no surface mount) components, available from all major suppliers. and can easily be put together in an evening.
With this you can receive local DATV activity from 2m to 13cm, including digital TV repeaters, and with a satellite dish and LNB, you can watch the activity on QO-100. See this page for more details on QO100
You will need the normal aerials, filters/pre-amps and/or LNB depending on the band you want to receive. Having said that it is relatively sensitive enough on its own to be able to receive nearby activity - and probably your local digital TV repeater.
DATV transmit
For more details see https://wiki.batc.org.uk/The_Portsdown_Transmitter
The Portsdown 4 software includes everything you need - just make sure you have the latest build - and plug your tuner card in to the Pi's USB port. See https://wiki.batc.org.uk/Portsdown_4_Pluto for more details.
