Revision as of 12:55, 3 January 2017 by G8GTZ (talk | contribs)
The Portsdown DATV transmitter project provides an easy way to “get on air” with Digital ATV at a relatively low cost, covers most of the common modes and involves some basic construction.
At the heart of the Portsdown project transmitter is a Raspberry Pi (RPi) computer running a BATC customised version of the F5OEO rpidatv software. The choice of the RPi is primarily due to the fact that it has an on-board MPEG-4 (H264) encoder and the versatile hardware interface (GPIO) capabilities. A touch screen interface on the RPi enables the system to be used without further need to connect up keyboard and mouse. If the LCD is not available, the system can be controlled by keyboard and mouse or using an external PC connected over a wired or wi-fi network. The Portsdown RPi software is capable of controlling the ADF4351 Local Oscillator module to give an output for 146 MHz, 437MHz and 23cms.
• Symbol rates to include the Reduced Bandwidth (RB-TV) modes and “normal” DATV modes
• Fully documented and supported including easy software installation and upgrades 1-1 Block Diagram.jpg
