Using LimeSDR with Portsdown
Revision as of 09:06, 20 October 2021 by G8GKQ (talk | contribs) (→Basic Test)
The Portsdown software supports the LimeSDR Mini. Support for the LimeSDR USB is provided on a best-efforts basis, but not tested.
However, due to the limited CPU power of the Raspberry Pi, many LimeSDR transmit modes are limited to 1MS and below.
Setting up the system
Hardware Installation
If you are using a Rapsberry Pi 3, both the LimeSDR Mini and USB versions have a greater power consumption than the RPi can comfortably power from its USB 2 ports. Therefore, it is recommended that a powered USB 2 hub be connected to the RPi, and the LimeSDR be plugged into one of the ports on the hub.
If you are using a Raspberry Pi 4, its USB ports have enough power to supply a LimeSDR Mini or USB, so a hub is not required. For some reason, the LimeSDR Mini sometimes works better when connected to the USB2 ports (the black ones, not the Blue ones).
The BATC 4-band and 8-band PTT drive and RF switching boards can be used with the Lime to provide band switching - see below for details on the GPIO port connections. When using the 8-band switch, make sure to use the latest version with the attenuating resistors between the MMIC and the switch ICs.
Installing the Lime Software
The LimeSuite software version 20.10.0 (Interface version v2021.10.0, Binary Interface 20.10-1) is loaded as part of the normal Portsdown build and update process. This may not be the latest version, but is compatible with other components of the Portsdown software and the latest DATV Express version.
Once installed, you can use your Portsdown to update the firmware and gateware on your LimeSDR (Mini or USB) to the compatible version, but you must be connected to the internet whilst upgrading a LimeSDR USB. The firmware to upgrade a LimeSDR Mini is stored on the Portsdown as part of the Portsdown build process.
Lime Configuration Menu
The "Lime Config" Menu is selected from Menu 3. Selecting "LimeUtil Info" displays the current version of LimeSuite.
The "Update Lime FW" button updates the Lime SDR firmware and gateware to the appropriate version for the installed LimeSuite. For recent Portsdown software versions, the correct version is shown below. You should see the same screen after selecting "Lime FW Info".
The Lime firmware/gateware version that works with the Portsdown is also compatible with DATV Express versions V1.25lp12 and later.
Using a LimeSDR USB
You can also use the more expensive LimeSDR USB (as opposed to the LimeSDR Mini) with the Portsdown. You can update the gateware and firmware to the correct version (Firmware Version 4, Gateware version 2.20), but the Lime Report will fail as it is designed for the LimeSDR Mini. The Portsdown should operate normally with a LimeSDR USB, although this is not a configuration that is tested before the release of software updates.
Basic Test
You can run a basic test on your LimeSDR Mini, by pressing the "Lime Report" button. Note that this test generates RF output and leaves the LimeSDR Mini generating a carrier on 1095 MHz at about -25 dBm. This test rarely passes unless the LimeSDR Mini is cold and the RF ports are disconnected. A functional test (transmitting, or receiving using BandViewer) is a better indication of LimeSDR Mini health.
First power tests with Lime Mini SDR Portsdown at M0YDH
Transmitting
Limitations
The BATC 4-band and 8-band PTT drive and RF switching boards can be used with the LimeSDR to provide multiband RF and PTT steering. They can remain connected to the RPi GPIO using the standard Portsdown GPIO interface board or (if you are prepared to accept the risk of damaging your LimeSDR Mini) connected to the Lime FPGA GPIO.
The LimeSDR Mini GPIOs 0, 1 and 2 give the same signals as the RPi Band LSB, NSB and MSB. GPIO 7 gives the PTT signal. These can be taken from J5 on the LimeSDR Mini https://wiki.myriadrf.org/LimeSDR-Mini_v1.1_hardware_description . For the LimeSDR USB, the GPIO signals are available on J18; the PTT signal is reported to be on FPGA-GPIO 5 (pin 8 in header), but this has not been investigated.
The pins are described here http://wiki.myriadrf.org/LimeSDR-USB_hardware_description.  Note that these outputs are not buffered and if damaged could prevent the LimeSDR from working again.  Our advice is the use the RPi GPIOs.
The gain provided by the 8-way RF switch is useful to maintain current levels (5 - 10 mW) at the output. To ensure the correct output levels are available, C16 (2p7) needs reducing to 1pf, and R5 (68 ohms) needs replacing with a wire link. Alternatively R5 could be simply be replaced with a 2p2 or 1p8 capacitor and C16 left as 2p7.
System Diagram
Acknowledgements
