Repeater Controller
Revision as of 17:28, 13 February 2022 by G8GTZ (talk | contribs) (→‎Customisation)
Typical operation
The BATC repeater controller will control either a single or multiple video switchers either by InfraRed or GPIO pins and will generate a carousel of scenes.
On receipt of a valid signal from, for example, a Ryde receiver, the controller will, key the transmitter, play an image for .5 seconds indicating which input has been activated and then switch to that input. When the receiver closes, the logic will play a Kimage and optional K in Morse, dekey the tx and go back to the carousel.
Switcher configurations
The basic design uses one or 2 IR transmitters to control one or 2 HDMI switches.
Configuring IR Switching
The IR codes for the HDMI switches used on your repeater will need to entered in the configuration file.
Customisation
While this software is designed to work "out of the box" it will need to be configured for each individual repeater (with callsign at the very least).
Most configuration can be done using the SSH menu - for more details see the Repeater Controller configuration page.
Most customisation will require the careful editing of the text file /home/pi/atv-rptr/config/repeater_config.txt; following this, the repeater will need to be rebooted to load the new settings (although you can just type "restart" at the ssh command prompt for testing). Some real-time control is possible using the ssh Console Menu (type menu at the ssh command prompt), but the configuration file is too comprehensive for all the functions to be edited from a simple menu.
Project status
Switching Logic
GPIO Connections
The repeater controller will switch a GPIO output to indicate one of up to eight receiver inputs has been activated.
This can be used to control an external video switcher but note care MUST be taken to buffer the 3.3 volt logic levels used on the Raspberry Pi GPIO pins.
