This page describes the set up of the BATC repeater controller - it should only be attempted by advanced users.
Enter the repeater controller menu log in to the RPi by SSH using a program such as Putty and type menu.
Reload
Behaviour
1 - Audio keepalive. Some HDMI switches shut down the audio channel is no audio is present. This option puts low-level white noise on the controller audio out to prevent this from happening.
5 - Operating hours. Select if transmit key line is active continuously or just during a timed period to save power. If timed, select the start and stop times.
11 - Apply changes
12 - Return to main menu
