Revision as of 18:25, 13 February 2022 by G8GTZ (talk | contribs)
Enter the repeater controller menu log in to the RPi by SSH using a program such as Putty and type menu.
Reload
1 Behaviour
11 - Apply changes
12 - Return to main menu
2 Callsign
3 Inputs
10 - Apply
11 - Main Menu
4 Control
5 Update
6 Settings
1 - Reset factory defaults
3 - Main menu.
7 Diagnostics
8 Reboot
