SSH Menu
Some configuration can be done using the SSH menu and some real-time control is possible using the ssh Console Menu.
Reload
1 Behaviour
11 - Apply changes
12 - Return to main menu
2 Callsign
3 Inputs
10 - Apply
11 - Main Menu
4 Control
5 Update
6 Settings
1 - Reset factory defaults
3 - Main menu.
7 Diagnostics
8 Reboot
Editing the config file
# Text file defining behaviour and config of the BATC HDMI Repeater Design
  1. Comments must be on their own line
  2. Read at boot time. Only modified from console menu or text editor
  1. Station Details
callsign=GB3HV locator=IO91LD
  1. Video output: hdmi720, hdmi1080, pal, ntsc
  2. Used to size captions and layout display. NOT to set output
vidout=hdmi1080
  1. Turn on low level audio noise to keep hdmi audio active? yes/no
audiokeepalive=yes
  1. Enable/disable transmit ptt active? yes/no
transmitenabled=yes
  1. Beacon mode only transmits carousel with ident. Set to no for rptr operation. yes/no
beaconmode=no
  1. Continuous TX or power-saving. no/yes
transmitwhennotinuse=yes
  1. Continuous operation or active hours only. yes/no
24houroperation=yes
  1. Power save during second half hour in active hours? Default no.
  2. Repeat and Ident are available/active during this time
halfhourpowersave=no
  1. Operating times are UTC. Ignored for 24/7 operation
operatingtimestart=1300 operatingtimefinish=2330
  1. Quiet hours behaviour:
repeatduringquiethours=no identduringquiethours=no
  1. Transmit PTT Demand physical pin (available pins are 40 .....)
pttgpiopin=40
  1. Local (144.75 FM from usb audio dongle) audio could be inserted on carousel
  2. Options are off, both, left right (mono from USB dongle)
carouselusbaudiomode=off carouselusbaudiogain=100
  1. DTMF control
  2. Control is on/off. Gain is %. Timeout is in seconds
  3. All dtmf codes are of the format *xx#. Only xx are defined below. Examples:
dtmfcontrol=on dtmfaudiogain=62 dtmfactiontimeout=600 dtmfreset=00 dtmfstatusview=01 dtmfquadview=04
  1. Keeper codes are 5 digit and must start with 9 (*9xxxx#)
dtmfkeepertxoff=97350 dtmfkeepertxon=97351 dtmfkeeperreboot=97359
dtmfselectinput0=10 dtmfselectinput1=11 dtmfselectinput2=12 dtmfselectinput3=13 dtmfselectinput4=14 dtmfselectinput5=15 dtmfselectinput6=16 dtmfselectinput7=17
  1. Accessory DTMF Control examples
dtmfoutputs=1 dtmfgpioout1pin=8 dtmfgpioout1label=shack_light dtmfgpioout1on=31 dtmfgpioout1off=41
dtmfinputs=1 dtmfgpioin1pin=8 dtmfgpioin1label=cabinet_door
  1. Background image for Caption Slides
  1. Ident info (audio is on/off) Pitch in Hz, speed in wpm, level is %
identinterval=900 identmediatype=jpg identmediaduration=5 identmediafile=/home/pi/tmp/ident.jpg identcwaudio=on identcwspeed=15 identcwpitch=800 identcwlevel=50 identcwfile=/home/pi/tmp/ident.wav
  1. K info. Pitch in Hz, speed in wpm, level is %
kmediatype=jpg kmediaduration=5 kmediafile=/home/pi/tmp/k.jpg kcwaudio=on kcwspeed=20 kcwpitch=800 kcwlevel=50 kcwfile=/home/pi/tmp/k.wav
  1. Carousel info. Max 99 scenes
  2. options for type are jpg, (mp4 not implemented yet), status or source. For source, file is source number
  3. which can be a virtual source such as a grid of 4 images
carouselscenes=5
  1. Input config
  2. Recommended gpio pins for "input active" are 32, 35, 18, 22, 16, 19 and 21
  1. announcemediatype determines the player used
  1. hdmi switcher can use "ir" or "gpio"
  2. IR uses a TX on GPIO pin 12
  3. GPIO uses pins 36, 37, 38, 33, 31, 29, 23, 24
  1. activeinputhold (yes/no) means that lower priority inputs do not get replaced by higher priority (except pri 1)
  2. Show Quad is yes/no
availableinputs=4 activeinputhold=no showquadformultipleinputs=yes
outputswitchcontrol=ir showoutputongpio=yes outputhdmiresetcode=nec:0x17 output2ndhdmicode=nec:0x08 outputhdmiquadcode=nec:0x18
input0name=Controller output0code=nec:0x17 output0hdmiswitchpin=36
input1name=Stream Input input1prioritylevel=1 input1activegpiopin=32 output1code=nec:0x12 output1hdmiswitchpin=37 input1announcemediatype=jpg input1announcemediafile=/home/pi/tmp/input1.jpg input1announcemediaduration=3
input2name=QO-100 RX input2prioritylevel=2 input2activegpiopin=21 output2code=nec:0x59 output2hdmiswitchpin=38 input2announcemediatype=jpg input2announcemediafile=/home/pi/tmp/input2.jpg input2announcemediaduration=3
input3name=3.4 GHz Ryde input3prioritylevel=3 input3activegpiopin=18 output3code=nec:0x08 output3hdmiswitchpin=33 input3announcemediatype=jpg input3announcemediafile=/home/pi/tmp/input3.jpg input3announcemediaduration=3
input4name=Quad View input4prioritylevel=7 input4activegpiopin=22 output4code=nec:0x18 output4hdmiswitchpin=31 input4announcemediatype=jpg input4announcemediafile=/home/pi/tmp/input4.jpg input4announcemediaduration=3
input5name=Mast Camera input5prioritylevel=7 input5activegpiopin=16 output5code=2nec:0x12 output5hdmiswitchpin=29 input5announcemediatype=jpg input5announcemediafile=/home/pi/tmp/input5.jpg input5announcemediaduration=10
input6name=Unused 6 input6prioritylevel=9 input6activegpiopin=19 output6code=2nec:0x59 output6hdmiswitchpin=23 input6announcemediatype=jpg input6announcemediafile=/home/pi/tmp/input6.jpg input6announcemediaduration=3
input7name=Unused 7 input7prioritylevel=9 input7activegpiopin=21 output7code=2nec:0x08 output7hdmiswitchpin=24 input7announcemediatype=jpg input7announcemediafile=/home/pi/tmp/input7.jpg input7announcemediaduration=3
