SSH Menu
Some configuration can be done using the SSH menu and some real-time control is possible using the ssh Console Menu.
Reload
1 Behaviour
11 - Apply changes
12 - Return to main menu
2 Callsign
3 Inputs
10 - Apply
11 - Main Menu
4 Control
5 Update
6 Settings
1 - Reset factory defaults
3 - Main menu.
7 Diagnostics
8 Reboot
Editing the config file
Typical config file
Intro
- Text file defining behaviour and config of the BATC HDMI Repeater Design
- Comments must be on their own line
- Read at boot time. Only modified from console menu or text editor
Station Details
callsign=GB3HV locator=IO91LD
Video output: hdmi720, hdmi1080, pal, ntsc Used to size captions and layout display. NOT to set output
vidout=hdmi1080
audiokeepalive=yes
transmitenabled=yes
Beacon mode only transmits carousel with ident. Set to no for rptr operation. yes/no
beaconmode=no
Continuous TX or power-saving. no/yes
transmitwhennotinuse=yes
24houroperation=yes
Power save during second half hour in active hours? Default no. Repeat and Ident are available/active during this time
halfhourpowersave=no
Operating times are UTC. Ignored for 24/7 operation
operatingtimestart=1300 operatingtimefinish=2330
Quiet hours behaviour:
repeatduringquiethours=no identduringquiethours=no
Transmit PTT Demand physical pin (available pins are 40 .....)
pttgpiopin=40
Local (144.75 FM from usb audio dongle) audio could be inserted on carousel Options are off, both, left right (mono from USB dongle)
carouselusbaudiomode=off carouselusbaudiogain=100
DTMF control Control is on/off. Gain is %. Timeout is in seconds All dtmf codes are of the format *xx#. Only xx are defined below. Examples:
dtmfcontrol=on dtmfaudiogain=62 dtmfactiontimeout=600 dtmfreset=00 dtmfstatusview=01 dtmfquadview=04
Keeper codes are 5 digit and must start with 9 (*9xxxx#)
dtmfkeepertxoff=97350 dtmfkeepertxon=97351 dtmfkeeperreboot=97359
dtmfselectinput0=10 dtmfselectinput1=11 dtmfselectinput2=12 dtmfselectinput3=13 dtmfselectinput4=14 dtmfselectinput5=15 dtmfselectinput6=16 dtmfselectinput7=17
Accessory DTMF Control examples
dtmfoutputs=1 dtmfgpioout1pin=8 dtmfgpioout1label=shack_light dtmfgpioout1on=31 dtmfgpioout1off=41
dtmfinputs=1 dtmfgpioin1pin=8 dtmfgpioin1label=cabinet_door
Ident info (audio is on/off) Pitch in Hz, speed in wpm, level is %
identinterval=900 identmediatype=jpg identmediaduration=5 identmediafile=/home/pi/tmp/ident.jpg identcwaudio=on identcwspeed=15 identcwpitch=800 identcwlevel=50 identcwfile=/home/pi/tmp/ident.wav
K info. Pitch in Hz, speed in wpm, level is %
kmediatype=jpg kmediaduration=5 kmediafile=/home/pi/tmp/k.jpg kcwaudio=on kcwspeed=20 kcwpitch=800 kcwlevel=50 kcwfile=/home/pi/tmp/k.wav
Carousel info. Max 99 scenes. Options for type are jpg, (mp4 not implemented yet), status or source. For source, file is source number which can be a virtual source such as a grid of 4 images
carouselscenes=5
Input config - Recommended gpio pins for "input active" are 32, 35, 18, 22, 16, 19 and 21
hdmi switcher can use "ir" or "gpio" - IR uses a TX on GPIO pin 12 - GPIO uses pins 36, 37, 38, 33, 31, 29, 23, 24
activeinputhold (yes/no) means that lower priority inputs do not get replaced by higher priority (except pri 1) Show Quad is yes/no
availableinputs=4 activeinputhold=no showquadformultipleinputs=yes
outputswitchcontrol=ir showoutputongpio=yes outputhdmiresetcode=nec:0x17 output2ndhdmicode=nec:0x08 outputhdmiquadcode=nec:0x18
input0name=Controller output0code=nec:0x17 output0hdmiswitchpin=36
input1name=Stream Input input1prioritylevel=1 input1activegpiopin=32 output1code=nec:0x12 output1hdmiswitchpin=37 input1announcemediatype=jpg input1announcemediafile=/home/pi/tmp/input1.jpg input1announcemediaduration=3
input2name=QO-100 RX input2prioritylevel=2 input2activegpiopin=21 output2code=nec:0x59 output2hdmiswitchpin=38 input2announcemediatype=jpg input2announcemediafile=/home/pi/tmp/input2.jpg input2announcemediaduration=3
input3name=3.4 GHz Ryde input3prioritylevel=3 input3activegpiopin=18 output3code=nec:0x08 output3hdmiswitchpin=33 input3announcemediatype=jpg input3announcemediafile=/home/pi/tmp/input3.jpg input3announcemediaduration=3
input4name=Quad View input4prioritylevel=7 input4activegpiopin=22 output4code=nec:0x18 output4hdmiswitchpin=31 input4announcemediatype=jpg input4announcemediafile=/home/pi/tmp/input4.jpg input4announcemediaduration=3
input5name=Mast Camera input5prioritylevel=7 input5activegpiopin=16 output5code=2nec:0x12 output5hdmiswitchpin=29 input5announcemediatype=jpg input5announcemediafile=/home/pi/tmp/input5.jpg input5announcemediaduration=10
input6name=Unused 6 input6prioritylevel=9 input6activegpiopin=19 output6code=2nec:0x59 output6hdmiswitchpin=23 input6announcemediatype=jpg input6announcemediafile=/home/pi/tmp/input6.jpg input6announcemediaduration=3
input7name=Unused 7 input7prioritylevel=9 input7activegpiopin=21 output7code=2nec:0x08 output7hdmiswitchpin=24 input7announcemediatype=jpg input7announcemediafile=/home/pi/tmp/input7.jpg input7announcemediaduration=3
