Revision as of 09:42, 14 February 2022 by G8GTZ (talk | contribs) (→‎DTMF control)
SSH Menu
Reload
1 Behaviour
11 - Apply changes
12 - Return to main menu
2 Callsign
3 Inputs
10 - Apply
11 - Main Menu
4 Control
5 Update
6 Settings
1 - Reset factory defaults
3 - Main menu.
7 Diagnostics
8 Reboot
Editing the config file
Typical config file
callsign=GB3HV locator=IO91LD
Video output
Used to size captions and layout display.  NOT to set output hdmi720, hdmi1080, pal, ntsc
vidout=hdmi1080
audiokeepalive=yes
transmitenabled=yes
beaconmode=no
transmitwhennotinuse=yes
24houroperation=yes
halfhourpowersave=no
operatingtimestart=1300
operatingtimefinish=2330
Quiet hours behaviour:
repeatduringquiethours=no
identduringquiethours=no
(available pins are 40 .....)
pttgpiopin=40
Local audio
carouselusbaudiomode=off
carouselusbaudiogain=100
DTMF repeater control
dtmfcontrol=on
dtmfaudiogain=62
dtmfactiontimeout=600
dtmfreset=00
dtmfstatusview=01
dtmfquadview=04
DTMF Keeper codes
dtmfkeepertxoff=97350
dtmfkeepertxon=97351
Turns Tx key on / off
dtmfkeeperreboot=97359
Reboot controller
dtmfselectinput0=10
dtmfselectinput1=11
dtmfselectinput2=12
dtmfselectinput3=13
dtmfselectinput4=14
dtmfselectinput5=15
dtmfselectinput6=16
dtmfselectinput7=17
Displays selected video source
dtmfoutputs=1
dtmfgpioout1pin=8
dtmfgpioout1label=shack_light
dtmfgpioout1on=31
dtmfgpioout1off=41
dtmfinputs=1
dtmfgpioin1pin=8
dtmfgpioin1label=cabinet_door
Ident info
identinterval=900
identmediatype=jpg
identmediaduration=5
identcwaudio=on
identcwspeed=15
identcwpitch=800
identcwlevel=50
K information
kmediatype=jpg
kmediaduration=5
kmediafile=/home/pi/tmp/k.jpg
kcwaudio=on
kcwspeed=20
kcwpitch=800
kcwlevel=50
kcwfile=/home/pi/tmp/k.wav
Carousel information
The carousel can have up to 99 scenes. Each scene can either be jpg, (mp4 not implemented yet), status screen or a video source on the switcher.  Jpeg images are read each time the file is displayed.  For a video source, "file" is source number which can be an individual source or the multi grid, if supported by the video switch.
carouselscenes=5
Input configuration
Show Quad is yes/no
availableinputs=4
activeinputhold=no
showquadformultipleinputs=yes
Output video switch config
outputswitchcontrol=ir
showoutputongpio=yes
outputhdmiresetcode=nec:0x17
Configure 2nd IR output
output2ndhdmicode=nec:0x08
outputhdmiquadcode=nec:0x18
input0name=Controller
output0code=nec:0x17
output0hdmiswitchpin=36
Configure input 1
input1name=Stream Input
input1prioritylevel=1
input1activegpiopin=32
output1code=nec:0x12
output1hdmiswitchpin=37
input1announcemediatype=jpg
input1announcemediaduration=3
Configure input 2
input2name=QO-100 RX
input2prioritylevel=2
input2activegpiopin=21
output2code=nec:0x59
output2hdmiswitchpin=38
input2announcemediatype=jpg
input2announcemediaduration=3
Configure input 3
input3name=3.4 GHz Ryde
input3prioritylevel=3
input3activegpiopin=18
output3code=nec:0x08
output3hdmiswitchpin=33
input3announcemediatype=jpg
input3announcemediaduration=3
Input 4 configuration
input4name=Quad View
input4prioritylevel=7
input4activegpiopin=22
output4code=nec:0x18
output4hdmiswitchpin=31
input4announcemediatype=jpg
input4announcemediaduration=3
Input 5 configuration
input5name=Mast Camera
input5prioritylevel=7
input5activegpiopin=16
output5code=2nec:0x12
output5hdmiswitchpin=29
input5announcemediatype=jpg
Input 6 configuration
input6name=Unused 6
input6prioritylevel=9
input6activegpiopin=19
output6code=2nec:0x59
output6hdmiswitchpin=23
input6announcemediatype=jpg
input6announcemediaduration=3
Input 7 configuration
input7name=Unused 7
input7prioritylevel=9
input7activegpiopin=21
output7code=2nec:0x08
output7hdmiswitchpin=24
input7announcemediatype=jpg
input7announcemediaduration=3
