SSH Menu
Reload
1 Behaviour
5 - Operating hours. Selection of transmit key line to be active continuously or just during a timed period to save power. If timed, select the start and stop times. Note time is set using UTC time, not local time.
8 - Half hour. If enabled, the transmitter transmitter will only be keyed in beacon mode during the first 30 minutes of every hour and not during the 2nd half hour to save power.
11 - Apply changes
12 - Return to main menu
2 Callsign
3 Inputs
10 - Apply
11 - Main Menu
4 Control
5 Update
6 Settings
1 - Reset factory defaults
3 - Main menu.
7 Diagnostics
8 Reboot
Editing the config file
Typical config file
Text file defining behaviour and config of the BATC HDMI Repeater Design Comments must be on their own line Read at boot time. Only modified from console menu or text editor
callsign=GB3HV locator=IO91LD
Video output
Used to size captions and layout display only. It does NOT set the output to hdmi720, hdmi1080, pal, ntsc
vidout=hdmi1080
audiokeepalive=yes
transmitenabled=yes
Beacon mode only transmits carousel with ident. Set to no for rptr operation. yes/no
beaconmode=no
Continuous TX or power-saving. no/yes
transmitwhennotinuse=yes
24houroperation=yes
Power save during second half hour in active hours? Default no. Repeat and Ident are available/active during this time
halfhourpowersave=no
Operating times are UTC. Ignored for 24/7 operation
operatingtimestart=1300
operatingtimefinish=2330
Quiet hours behaviour:
repeatduringquiethours=no
identduringquiethours=no
(available pins are 40 .....)
pttgpiopin=40
Local audio
(144.75 FM from usb audio dongle) audio could be inserted on carousel Options are off, both, left right (mono from USB dongle)
carouselusbaudiomode=off
carouselusbaudiogain=100
DTMF repeater control
Control is on/off. Gain is %. Timeout is in seconds
dtmfcontrol=on
dtmfaudiogain=62
dtmfactiontimeout=600
All dtmf codes are of the format *xx#. Only xx are defined below. Examples:
dtmfreset=00
dtmfstatusview=01
dtmfquadview=04
dtmfselectinput0=10
dtmfselectinput1=11
dtmfselectinput2=12
dtmfselectinput3=13
dtmfselectinput4=14
dtmfselectinput5=15
dtmfselectinput6=16
dtmfselectinput7=17
DTMF Keeper codes
Examples:
dtmfkeepertxoff=97350
dtmfkeepertxon=97351
Turns Tx key on / off
dtmfkeeperreboot=97359
Reboot controller
DTMF input can also be used to control external equipment via the GPIO pins
dtmfoutputs=1
dtmfgpioout1pin=8
dtmfgpioout1label=shack_light
dtmfgpioout1on=31
dtmfgpioout1off=41
dtmfinputs=1
dtmfgpioin1pin=8
dtmfgpioin1label=cabinet_door
Ident info
Audio is on/off, Pitch in Hz, speed in wpm, level is %
identinterval=900
identmediatype=jpg
identmediaduration=5
identcwaudio=on
identcwspeed=15
identcwpitch=800
identcwlevel=50
K information
kmediatype=jpg
kmediaduration=5
kmediafile=/home/pi/tmp/k.jpg
kcwaudio=on
kcwspeed=20
kcwpitch=800
kcwlevel=50
kcwfile=/home/pi/tmp/k.wav
Carousel information
The carousel can have up to 99 scenes. Each scene can either be jpg, (mp4 not implemented in current release), status screen or a video source on the switcher. Jpeg images are read each time the file is displayed. For a video source, "file" is source number which can be an individual source or the multi grid, if supported by the video switch.
carouselscenes=5
carousel02mediatype=jpg
carousel02file=/home/pi/atv-rptr/media/weather.JPG
carousel02mediaduration=10
carousel03mediatype=jpg
carousel03file=/home/pi/atv-rptr/media/75cbw.jpg
carousel03mediaduration=5
carousel04mediatype=jpg
carousel04file=/home/pi/atv-rptr/media/tropo.JPG
carousel04mediaduration=10
carousel05mediatype=source
carousel05file=4
carousel05mediaduration=30
Input configuration
hdmi switcher can use "ir" or "gpio" - IR uses a TX on GPIO pin 12 - GPIO uses pins 36, 37, 38, 33, 31, 29, 23, 24
activeinputhold (yes/no) means that lower priority inputs do not get replaced by higher priority (except pri 1) Show Quad is yes/no
availableinputs=4
activeinputhold=no
showquadformultipleinputs=yes
Output video switch config
outputswitchcontrol=ir
showoutputongpio=yes
outputhdmiresetcode=nec:0x17
Configure 2nd IR output
output2ndhdmicode=nec:0x08
outputhdmiquadcode=nec:0x18
input0name=Controller
output0code=nec:0x17
output0hdmiswitchpin=36
Configure input 1
input1name=Stream Input
input1prioritylevel=1
input1activegpiopin=32
output1code=nec:0x12
output1hdmiswitchpin=37
input1announcemediatype=jpg
input1announcemediaduration=3
Configure input 2
input2name=QO-100 RX
input2prioritylevel=2
input2activegpiopin=21
output2code=nec:0x59
output2hdmiswitchpin=38
input2announcemediatype=jpg
input2announcemediaduration=3
Configure input 3
input3name=3.4 GHz Ryde
input3prioritylevel=3
input3activegpiopin=18
output3code=nec:0x08
output3hdmiswitchpin=33
input3announcemediatype=jpg
input3announcemediaduration=3
Input 4 configuration
input4name=Quad View
input4prioritylevel=7
input4activegpiopin=22
output4code=nec:0x18
output4hdmiswitchpin=31
input4announcemediatype=jpg
input4announcemediaduration=3
Input 5 configuration
input5name=Mast Camera
input5prioritylevel=7
input5activegpiopin=16
output5code=2nec:0x12
output5hdmiswitchpin=29
input5announcemediatype=jpg
Input 6 configuration
input6name=Unused 6
input6prioritylevel=9
input6activegpiopin=19
output6code=2nec:0x59
output6hdmiswitchpin=23
input6announcemediatype=jpg
input6announcemediaduration=3
Input 7 configuration
input7name=Unused 7
input7prioritylevel=9
input7activegpiopin=21
output7code=2nec:0x08
output7hdmiswitchpin=24
input7announcemediatype=jpg
input7announcemediaduration=3
