SSH Menu
Reload
1 Behaviour
5 - Operating hours. Selection of transmit key line to be active continuously or just during a timed period to save power. If timed, select the start and stop times. Note time is set using UTC time, not local time.
8 - Half hour. If enabled, the transmitter will only be keyed in beacon mode during the first 30 minutes of every hour and not during the 2nd half hour to save power.
11 - Apply changes
12 - Return to main menu
2 Callsign
3 Inputs
10 - Apply
11 - Main Menu
4 Control
5 Update
6 Settings
1 - Reset factory defaults
3 - Main menu.
7 Diagnostics
8 Reboot
Editing the config file
Typical config file
Text file defining behaviour and config of the BATC HDMI Repeater Design Comments must be on their own line Read at boot time and only modified from console menu or text editor except transmitenabled which is amended by dtmfkeepertxoff or dtmfkeepertxon
callsign=GB3HV
locator=IO91LD
Video output
Used to size captions and layout display only. It does NOT set the output to hdmi720, hdmi1080, pal, ntsc
vidout=hdmi1080
Ident and K CW audio output
This is used to set the output port (but not the hdmi keep-alive) hdmi, jack or usb
audioout=hdmi
audiokeepalive=yes
audiokeepalivelevel=85
transmitenabled=yes
Beacon mode only transmits carousel with ident. Set to no for rptr operation. yes/no
beaconmode=no
Continuous TX or power-saving. no/yes
transmitwhennotinuse=yes
24houroperation=yes
Power save during second half hour in active hours? Default no. Repeat and Ident are available/active during this time
halfhourpowersave=no
Operating times are UTC. Ignored for 24/7 operation
operatingtimestart=1300
operatingtimefinish=2330
Quiet hours behaviour:
repeatduringquiethours=no
identduringquiethours=no
Recommended pin 40
pttgpiopin=40
Front Panel Shutdown Enabled?
Physical GPIO Pin (recommended 26)
fpshutdown=no
fpsdgpiopin=26
Local audio
(144.75 FM from usb audio dongle) audio could be inserted on carousel Options are off, both, left right (mono from USB dongle)
carouselusbaudiomode=off
carouselusbaudiogain=100
DTMF repeater control
Uses white "Portsdown/Langstone" USB dongle input
These are just example commands - see DATV repeater DTMF commands for more details
Control is on/off. Gain is %. Timeout is in seconds
dtmfcontrol=on
dtmfaudiogain=62
dtmfactiontimeout=600
All dtmf codes are of the format *xx#. Only xx isdefined below. Examples:
dtmfreset=00
To display the controller status screen - includes GPIO pin status (see below)
dtmfstatusview=01
Select quad view
dtmfquadview=04
Select input
dtmfselectinput0=10
dtmfselectinput1=11
dtmfselectinput2=12
dtmfselectinput3=13
dtmfselectinput4=14
dtmfselectinput5=15
dtmfselectinput6=16
dtmfselectinput7=17
DTMF Keeper codes
In this example keeper codes are 5 digit and must start with 9 (*9xxxx#)
Turns Tx key on / off
dtmfkeepertxoff=97350
dtmfkeepertxon=97351
Reboot controller
dtmfkeeperreboot=97359
DTMF input can also be used to control external equipment via the GPIO pins - a maximum of 10 devices can be connected.
Number of outputs
dtmfoutputs=1
Pin allocations
dtmfgpioout1pin=8
Label for status screen
dtmfgpioout1label=shack_light
DTMF commands to turn on and off
dtmfgpioout1on=31
dtmfgpioout1off=41
GPIO inputs
The controller can monitor GPIO pins and display their status on the status screen, displayed by DTMF *01# Note: Due to an error in coding, these functions are called "dtmf"gpio inputs.
Number of inputs
dtmfinputs=1
Pin allocationa
dtmfgpioin1pin=8
dtmfgpioin1label=cabinet_door
Caption cards such as "K" and input identification are built by the controller on this back ground - to change this, replace the .jpg with a different file of the same resolution
Ident info
Audio is on/off, Pitch in Hz, speed in wpm, level is %
identinterval=900
identmediatype=jpg
identmediaduration=5
identcwaudio=on
identcwspeed=15
identcwpitch=800
identcwlevel=50
K information
kmediatype=jpg
kmediaduration=5
kmediafile=/home/pi/tmp/k.jpg
kcwaudio=on
kcwspeed=20
kcwpitch=800
kcwlevel=50
kcwfile=/home/pi/tmp/k.wav
Carousel information
The carousel can have up to 99 scenes. Each scene can either be jpg, (mp4 not implemented in current release), status screen or a video source on the switcher. Jpeg images are read each time the file is displayed. For a video source, "file" is source number which can be an individual source or the multi grid, if supported by the video switch.
carouselscenes=5 carousel01mediatype=jpg carousel01file=/home/pi/atv-rptr/media/HVtest.jpg carousel01mediaduration=10 carousel02mediatype=jpg carousel02file=/home/pi/atv-rptr/media/weather.JPG carousel02mediaduration=10 carousel03mediatype=jpg carousel03file=/home/pi/atv-rptr/media/75cbw.jpg carousel03mediaduration=5 carousel04mediatype=jpg carousel04file=/home/pi/custom_media/tropo.JPG carousel04mediaduration=10 carousel05mediatype=source carousel05file=4 carousel05mediaduration=30
The example above has 4 images and one source (so 5 scenes). The 5th scene is the quad view; source 4 is set up below to show the Quad to enable its inclusion in the carousel.
Note that the 4th image above is located in the /home/pi/custom_media folder. It is recommended that site-specific images are saved in that folder, which will not be over-written during software updates.
Input configuration
hdmi switcher can use "ir" or "gpio" - IR uses a TX on GPIO pin 12 - GPIO uses pins 36, 37, 38, 33, 31, 29, 23, 24
activeinputhold (yes/no) means that lower priority inputs do not get replaced by higher priority (except pri 1) Show Quad is yes/no
availableinputs=4
activeinputhold=no
showquadformultipleinputs=yes
Output video switch config
outputswitchcontrol=ir
showoutputongpio=yes
outputhdmiresetcode=nec:0x17
Configure 2nd IR output
output2ndhdmicode=nec:0x08
outputhdmiquadcode=nec:0x18
Bitfocus Companion Server Settings
# Bitfocus Companion (html) server address & port (no trailing slash) networkctrlurl=http://192.0.1.176:8888 # Other net commands have leading slash outputquadnetcommand=/press/bank/1/11
The configuration for the controller output 6 elements (currently).
The input0name is the text name displayed on the Configuration screen.
The IR code required to select the controller video and send it to the repeater output is stated in output0code. The format is protocol:hex code. A 2 is added to the beginning of the string if the the input is on the second, daisy-chained, hdmi switch (ie 2nec:0x17). If GPIO switching of outputs is used, the output0hdmiswitchpin indicates which pin should be used. If an i2c-controlled video switcher is used, output0i2cchannel indicates which channel should be selected to display that input. Similarly, if network commands are being used to control an ATEM switch through BitFocus companion, the tail end of the network command is defined by output0netcommand.
For audio i2c switching, the correct bit is set by output0audioi2cbit.
input0name=Controller output0code=nec:0x17 #output0code=2nec:0x17 (daisy chain) output0hdmiswitchpin=36 output0i2cchannel=1 output0netcommand=/press/bank/1/8 output0audioi2cbit=0
Configuration of External Inputs
The configuration for each input has 11 elements (currently).
The inputxname is the text name displayed on the "announce" caption and on the Configuration screen. The priority level can be set from 1 to 9. A priority level of 9 means that the input is not displayed unless it is viewed as part of the quad or is directly selected by a DTMF command.
The inputxactivegpiopin is the physical pin number that the attached receiver sets high to indicate that a signal is present. The IR code required to select the input and send it to the repeater output is stated in outputxcode. The format is protocol:hex code. A 2 is added to the beginning of the string if the the input is on the second, daisy-chained, hdmi switch (ie 2nec:0x12). If GPIO switching of outputs is used, the outputxhdmiswitchpin indicates which pin should be used. If an i2c-controlled video switcher is used, outputxi2cchannel indicates which channel should be selected to display that input. Similarly, if network commands are being used to control an ATEM switch through BitFocus companion, the tail end of the network command is defined by outputxnetcommand.
For audio i2c switching, the correct bit is set by outputxaudioi2cbit.
The default announce media settings work with the captions that are generated during repeater start-up. The can be cahnge for custom media if required.
Configure input 1
input1name=Stream Input input1prioritylevel=1 input1activegpiopin=32 output1code=nec:0x12 output1hdmiswitchpin=37 output1i2cchannel=2 output1netcommand=/press/bank/1/1 output1audioi2cbit=1 input1announcemediatype=jpg input1announcemediafile=/home/pi/tmp/input1.jpg input1announcemediaduration=3
Configure input 2
input2name=QO-100 RX input2prioritylevel=2 input2activegpiopin=35 output2code=nec:0x59 output2hdmiswitchpin=38 output2i2cchannel=3 output2netcommand=/press/bank/1/2 output2audioi2cbit=2 input2announcemediatype=jpg input2announcemediafile=/home/pi/tmp/input2.jpg input2announcemediaduration=3
Configure input 3
input3name=3.4 GHz Ryde input3prioritylevel=3 input3activegpiopin=18 output3code=nec:0x08 output3hdmiswitchpin=33 output3i2cchannel=4 output3netcommand=/press/bank/1/3 output3audioi2cbit=3 input3announcemediatype=jpg input3announcemediafile=/home/pi/tmp/input3.jpg input3announcemediaduration=3
Configure input 4
Input 4 is set to display the quad view. This enables it to be included in the carousel (as source 4).
input4name=Quad View input4prioritylevel=7 input4activegpiopin=22 output4code=nec:0x18 #output4code=2nec:0x12 (daisy chain, not quad) output4hdmiswitchpin=31 output4i2cchannel=5 output4netcommand=/press/bank/1/4 output4audioi2cbit=4 input4announcemediatype=jpg input4announcemediafile=/home/pi/tmp/input4.jpg input4announcemediaduration=3
Configure input 5
input5name=Mast Camera input5prioritylevel=7 input5activegpiopin=16 output5code=2nec:0x59 output5hdmiswitchpin=29 output5i2cchannel=6 output5netcommand=/press/bank/1/5 output5audioi2cbit=5 input5announcemediatype=jpg input5announcemediafile=/home/pi/tmp/input5.jpg input5announcemediaduration=10
Configure input 6
input6name=Unused 6 input6prioritylevel=9 input6activegpiopin=19 output6code=2nec:0x08 #output6code=2nec:0x08 (daisy chain) output6hdmiswitchpin=23 output6i2cchannel=7 output6netcommand=/press/bank/1/6 output6audioi2cbit=6 input6announcemediatype=jpg input6announcemediafile=/home/pi/tmp/input6.jpg input6announcemediaduration=3
Configure input 7
input7name=Unused 7 input7prioritylevel=9 input7activegpiopin=21 output7code=2nec:0x08 #output7code=2nec:0x12 (daisy chain) output7hdmiswitchpin=24 output7i2cchannel=8 output7netcommand=/press/bank/1/7 output7audioi2cbit=7 input7announcemediatype=jpg input7announcemediafile=/home/pi/tmp/input7.jpg input7announcemediaduration=3
