Portsdown 4
The Portsdown 4 transceiver software has been specifically designed to be used with the Raspberry Pi 4 and the official Raspberry Pi 7 inch touchscreen. It will drive a Pluto SDR or the LimeSDR.
- Raspberry Pi4 2GB model
- 7" touch screen
- 8, 16 or 32 GB SD card
- Adalm Pluto or Lime SDRmini SDR hardware
This will give you a DVB-S2 and DVB-T DATV transmit system from 30 to 3500 MHz when using a Lime SDR and 50MHz to 4100 MHz with the Pluto.
With the addition of a MiniTiouner USB receiver [[1]], you will have a full spec DVB-S/S2 DATV transceiver.
With the addition of the Knucker USB tuner you will also have DVB-T receive capabilities.
Building a Portsdown 4
Dave G8GKQ published this step by step guide to building a Portsdown 4 in CQ-TV 271:
media:Getting Started With Portsdown 4.pdf
Capabilities
Portsdown 4 transmit capabilities:
- DVB-S, DVB-S2 and DVB-T (H264 only) transmissions from a Pluto SDR connected by USB. More details here.
- DVB-S, DVB-S2 and DVB-T (MPEG-2 and H264) transmissions from a LimeSDR Mini or LimeSDR USB using stock LimeSDR firmware
- DVB-S and DVB-S2 (MPEG-2 and H264) transmissions from a LimeSDR Mini using "LimeDVB" firmware
- DVB-S (MPEG-2 and H264) transmissions from a DATV Express Board connected by USB
- Supported transmit video sources include the Raspberry Pi Camera, C920 WebCam or a USB-connected EasyCap composite video capture device
- Streaming to the BATC Streamer using the Raspberry Pi Camera or EasyCap composite video capture device as a source
Portsdown 4 receive capabilities:
When a MiniTiouner USB receiver is connected via USB:
- Reception and display of DVB-S and DVB-S2 (MPEG-2, H264 and H265) signals - see https://wiki.batc.org.uk/DVB-S/S2_Reception
When a BATC Knucker USB tuner is connected by USB:
- Reception and display of DVB-T and DVB-T2 (MPEG-2, H264 and H265) signals
When the Portsdown 4 is connected to the internet:
- Display of streams from the BATC Streamer
Received audio can be heard through either the Raspberry Pi AV socket or a compatible USB audio dongle.
Portsdown 4 test and alignment aids
- Control of a Pluto, LimeSDR Mini, DATV Express, ADF4351, Elcom and SLO Microwave Sources using the Portsdown 4 Signal Generator.
- Basic spectrum display of band occupancy using the "Portsdown Band Viewer" - note this requires a LimeSDR Mini to be connected.
Only the Raspberry Pi 4 and the Official 7 inch touchscreen (or the DFRobot DFR0550 5 inch touchscreen) are planned to be supported in the near future.
Portsdown 4 GPIO connections
Powering the LimeSDR
The Raspberry Pi 4 has increased power capabilities on its USB ports, so it is recommended that you connect the LimeSDR directly to the Raspberry Pi. For some reason, the LimeSDR Mini sometimes works better when connected to the USB2 ports (the black ones, not the blue ones).
Powering the Pluto
The Pluto is more reliable and less likely to drop out if fed with about 4.9v on USB. So, set the RPi input voltage to 5.0v, or use another power source to make sure that the Pluto is not fed with over 5.0v.
Portsdown hardware
Full details of the Portsdown hardware are available here.
The Portsdown 4 software is available on a pre-programmed SD card which you can buy from the BATC shop https://batc.org.uk/shop/portsdown-transmitter-pre-programmed-sd-card/
Langstone Narrow Band Transceiver
Note: the Langstone software needs a Pluto SDR to be connected by USB, and a compatible USB Audio dongle.
Pluto Capabilities
The Portsdown 4 support for the Pluto SDR is still under development and there are some limitations on functionality as described here Portsdown 4 Pluto.
FAQ
- Is it possible to rotate the PiCam image in software as it is on it's side?
- Can I upgrade from Langstone or a previous version incluing Portsdown A27?
- When I try to update I get the error "Unable to contact GitHub for update, Internet connection to Google seems OK". The solution is to log in by ssh and run the following commands:
cd /home/pi wget https://raw.githubusercontent.com/BritishAmateurTelevisionClub/portsdown4/master/update.sh -O /home/pi/update.sh chmod +x /home/pi/update.sh ./update.sh
- I have built my Portsdown 4 but the screen is upside down. How can I get it the right way up?
More information
For more information and to ask any questions see https://forum.batc.org.uk/viewtopic.php?f=103&t=6804
