Gerber Files
Ryde Front Panel
ADF4351 PIC Controller
DATV Repeater Audio Switch
G0MJW's Ryde board
G0MJW's PD4 board
TBC (after CAT22)
This is a PCB to implement a Portsdown 4 with 25 pid connector for interfacing to test equipment.
Schematic File:P4GPIO.pdf
Gerbers File:P4GPIO25Way.zip
G0MJW's HF3 relay board
Here's Mike's design for a SPDT relay PCB. The relay is General Purpose Relay, HF3 Series, High Frequency, Non Latching, SPDT, 12 VDC, 2 A. An surface mount diode e.g 1N4148 type, Molex KK connector and 3 SMA to PCB unions complete the build.
