Gerber Files
Revision as of 15:35, 31 March 2023 by M0YDH (talk | contribs) (→‎G0MJW's HF3 relay board)
Ryde Front Panel
File:Gerbers.zip
ADF4351 PIC Controller
File:adf435x.zip
DATV Repeater Audio Switch
G0MJW's Ryde board
File:RydeGpioV2.zip
File:ibom.zip
G0MJW's PD4 board
TBC (after CAT22)
This is a PCB to implement a Portsdown 4 with 25 pid connector for interfacing to test equipment.
Schematic File:P4GPIO.pdf
Gerbers File:P4GPIO25Way.zip
BOM File:ibom25way.zip
Here's Mike's design for a SPDT relay PCB. The relay is General Purpose Relay, HF3 Series, High Frequency, Non Latching, SPDT, 12 VDC, 2 A. Part number is dependant on the voltage in use in circuit. A surface mount diode e.g 1N4148 type, Molex KK connector and 3 SMA to PCB unions complete the build.
Gerbers File:HF3_relay_board_gerbers.zip
LNB bias tee and reference injection PCB
PCB Gerbers for the LNB Bias T and reference injection by Mike G0MJW in CQ-TV263 – or see BATC forum for more details: https://forum.batc.org.uk/viewtopic.php?f=15&t=3122&p=17416#p17343
File:BiasTGerbers.zip
M0RNW's G8TA Rx/Tx Changeover Controller Board
This is v1 designed for a latching relay of up to 6 into 1 ports using an Arduino Nano. Hopefully it features in CQ-TV-279. PCB is intended for rail mounting in a 3U cabinet.
Three SN754410NE H bridge driver ICs are used. The DC-DC boost converters are XL4005 type boards off EBay. U2 can be omitted - it's for an 18V supply to an LNB. Other components - see schematic.
Gerbers File:Rx-Tx_Changeover_Gerbers.zip
Schematic File:RxTx-Changeover.pdf_revised_20230207.pdf
Sketch for Arduino NanoFile:RxTxChangeoverV1.ino
