Oscar 100 has an 9 MHz wide band transponder dedicated to Digital Amateur Television.
Dish
To receive the DATV signals you will need at least a 90cms dish and preferably 1m or larger - see this guide as to how to align your dish on the Es'hail-2 satellite: https://wiki.batc.org.uk/Es%27hail-2_Basic_Information#Aligning_your_dish
LNB
Whilst any modern Ku band satellite LNB will receive the Oscar 100 signals, particularly the 2Ms beacon, it is recommended that you use a Phase Lock Loop LNB. This is because the frequency stability of a standard DRO unit will make it difficult to receive the Narrow Band transponder SSB signals and Reduced Bandwidth DATV (RB-TV) signals on the wide band transponder.
Note - it is recommended that you do not do any modifications to lock your LNB to an external source for DATV reception as it is beleived that these modifications can make DATV reception worse as they increase the phase noise of the LNB.
LNB power
All satellite receivers can do this - select LNB voltage in set up - and when using MiniTiouner this can be done by using a step up regulator from 12v (plenty on ebay) and feeding 18v in to F2 and put J3 and J4 links in to fed the selected LNB. https://wiki.batc.org.uk/images/6/6d/SERIF.pdf
What receiver to use
The frequencies in use are not standard satellite frequencies and the bit rates we use for ATV are lower than commercial satellites, the choice is limited.
To receive the wide band horizontally polarised DATV transponder you will need a DATV receiver capable of receiving 741 MHz to 749MHz.
Unfortunately this is outside the normal fequency tuning range of a standard consumer digital TV Set Top Box (STB). Therefore you will either need an additional up converter to shift the IF frequency up to be in the tuning range of the STB at L-band between 950 – 2150MHz. A Global ADX-Plus, an original Astra frequency extender or an SUP2400 converter previously sold by BATC will work.
Alternatively you can modify your PLL LNB by changing the 25MHz reference crystal to 26MHz to produce an IF output above 950MHz.
Standard satellite receivers
Once you have an upconverter or modified LNB you will be able to use a Free to Air DVBS2 (HD) receiver to receive the DATV beacon signal on 10,491.5 MHz which is transmitted using DVB-S2 1500 kS. Note, it must be a satellite receiver, not a terrestrial Freeview box, and a Sky box or similar service branded satellite box will not work - it must be a Free to Air (FTA) satellite box.
However, you will NOT be able to use most (95%) of consumer STB's to receive the Reduced bandwidth (RB-TV) signals which are typically 333Ks on Oscar 100.
Receivers designed for DATV
USB Receiver hardware
Mark 2 MiniTiouner PCB
PicoTuner PCB
It replaces the FTDI USB interface on the original PCB with a Rpi Pico module. The Pico is not only significantly cheaper (£5 vs £32) but enables 2 stations to be received at once when used on the QO100 satellite.
MiniTiouner Mk1 PCB
As well as covering the HAMTV frequency without a down converter, the Serit 4334 has much better RF performance than the original Sharp and Eardatek units and has been integrated into the OpenTuner, Ryde and Portsdown DATV receive systems.
Ryde
OpenTuner
Portsdown
MiniTiouner
PC software receivers
SDRs
Setting up your receiver
You will find it a lot easier to tune to the DATV signals on Oscar-100 if you put your LNB offset in to your receiver rather than try to enter the IF frequency such as 741.5MHz directly.
Most LNBs have a 9750 MHz local oscillator - when 9750000 is put in to your receiver offset (on MiniTiouner it is the white box directly below the frequency box) you can then just enter the 10 GHz freq shown on the spectrum display directly into your receiver.
Tuning to the signals
Once you have the system set up and you have successfully received the DATV beacon on 10491.5 MHz 1500 kSS DVB-S2 you will be ready to receive DATV signals.
If you have the correct symbol rate set for a signal, you may find the receiver AFC may pull your receiver on to the frequency. Therefore you may find you receive the beacon on 10491.5 MHz when your receiver is tuned to 10493MHz.
QO100 Live Tune
Rob M0DTS has developed a small application designed to run on a PC that grabs the fft data from the BATC Wideband Spectrum monitor page and allows the user to click on signals which automatically configures Minitioune to the required settings to receive the signal via udp control. See QO100 Live Tune for more details and download instructions.
Typical receive results
QO-100 DATV beacon - 10491.5 MHz, DVB-S2 1.5 MS FEC 4/5
The following (empty transponder) results are typical with a POTY feed using a "rocket" LNB lens:
Dish size Received MER
2.4m 12 dB
1.8m 11.5 dB
1.2m 10 dB
1m 9 dB
80cm 8 dB
70cm 7 dB
60cm 6 dB
Using an optimised LNB and horn, results could be up to 1 dB better as the POTY with lens is not perfect.
