Gerber Files
Revision as of 00:36, 8 March 2025 by G4KLB (talk | contribs)
Ryde Front Panel
File:Gerbers.zip
ADF4351 PIC Controller
File:adf435x.zip
DATV Repeater Audio Switch
G0MJW's Ryde board
File:RydeGpioV2.zip
File:ibom.zip
G0MJW's PD4 board
TBC (after CAT22)
This is a PCB to implement a Portsdown 4 with 25 pid connector for interfacing to test equipment and a PTT transistor that can switch light loads. There are also headers for the Langstone.
Schematic File:P4GPIO.pdf
Gerbers File:P4GPIO25Way.zip
BOM File:ibom25way.zip
Sorry there is no parts list for Farnell, etc because the parts they supply just change too often, see the BOM for inspiration. The resistors and capacitors are mostly standard 0805 SMD, there are two through hole 100uF 16V electrolytics, non critical as long as they fit and you may want to fit a larger 2512 SMD resistor in the fan supply to slow it down if too loud. The headers are Molex KK254 or equivalent, you only need to fit them if you plan to use them. The PI GPIO header socket is on the bottom of the board, take care not to fit it on the top by mistake! There are two PSU options, only one is needed. The small MCP1584 DC-DC module, as used in the Minitiouner, is probably the easiest to obtain, if you fit this there is no need for the voltage programming resistors R1, R2 and R3 which are needed with the alternative Murata module - see the schematic. Needless to say, the MCP1584 module pot has to be set for 5V before connecting the PI. The reverse protection diode can be almost anything that will survive until the 1.5A PTC fuse activates. I got my PCB mounting DB25 from AliExpress, but they are available from major suppliers. The dimensions vary between suppliers, so be sure to check the PCB footprint for the one you choose. The right one is fairly short and should be flush with the PI USB/Ethernet when you out it in a box.
G0MJW's HF3 relay board
Here's Mike's design for a SPDT relay PCB. The relay is General Purpose Relay, HF3 Series, High Frequency, Non Latching, SPDT, 12 VDC, 2 A. Part number is dependant on the voltage in use in circuit. A surface mount diode e.g 1N4148 type, Molex KK connector and 3 SMA to PCB unions complete the build.
Gerbers File:HF3_relay_board_gerbers.zip
LNB bias tee and reference injection PCB
PCB Gerbers for the LNB Bias T and reference injection by Mike G0MJW in CQ-TV263 – or see BATC forum for more details: https://forum.batc.org.uk/viewtopic.php?f=15&t=3122&p=17416#p17343
File:BiasTGerbers.zip
M0RNW's G8TA Rx/Tx Changeover Controller Board
This is v1 designed for a latching relay of up to 6 into 1 ports using an Arduino Nano. Hopefully it features in CQ-TV-279. PCB is intended for rail mounting in a 3U cabinet.
Three SN754410NE H bridge driver ICs are used. The DC-DC boost converters are XL4005 type boards off EBay. U2 can be omitted - it's for an 18V supply to an LNB. Other components - see schematic.
Gerbers File:Rx-Tx_Changeover_Gerbers.zip
Schematic File:RxTx-Changeover.pdf_revised_20230207.pdf
Sketch for Arduino NanoFile:RxTxChangeoverV1.ino
PE43703 Attenuator Controller
Gerber Files File:PE43703 ATTENUATOR CONTROLLER CW.docx
Project https://wiki.batc.org.uk/PE43703_2025
