GB3HV
GB3HV has Moved and is now on-air from IO91LD
We left our lovely Farnham site before Christmas 2021 but the good news is that Roy G8CKN is now hosting the repeater at his QTH in IO91LD - this is a great site with different coverage to Farnham but we are hoping all of you will still be able to access it.
Organisation
GB3HV will be managed by the GB3HV Repeater Group.
The Constitution is here: Media:20250423 GB3HV REPEATER GROUP CONSTITUTION.pdf
The Site Agreement with R & J Powers is here: Media:20250423 GB3HV Site Agreement.pdf
These documents were discussed and agreed at the inaugural meeting of the GB3HV repeater Group on Tuesday 29 April 2025. The record of the meeting is here: Media:20250429 GB3HV Repeater Group Formation Meeting Record.pdf
Equipment and rebuild
GB3HV has been rebuilt and is now digital in, digital out (with a 23 cm analogue RX). This has been made possible by the great work done by Dave G8GKQ on the BATC repeater controller project which uses HDMI video switchers - see https://wiki.batc.org.uk/Repeater_Controller
The Tuesday net at 8pm is still very active with a number of stations either coming in by the stream rxr or relayed in by other users receiving 10,499.25 MHz on QO-100.
Inputs and outputs
GB3HV receives on:
70 cms: 437 MHz DVB-S or DVB-S2 at 1MS and 333kS with a steerable beam.
23 cms: 1248 MHz DVB-S or DVB-S2 at 2MS, 1MS and 333kS with a steerable beam.
23 cms: 1248 MHz FM with a steerable beam.
GB3HV also has a stream input - contact G8GTZ or G8GKQ for details
GB3HV transmits on 1308 MHz DVB-S2, 1 MS, QPSK, FEC 2/3
GB3HV streams to https://batc.org.uk/live/gb3hv
Operating Times
When not switched off for maintenance, GB3HV operates at the following times (all UTC, does not change for BST):
Receivers: 10:00 to 23:30 (the "active hours")
Transmitter: from the hour until the half hour during the period 10:00 to 23:30.
The transmitter is turned on at any time between 10:00 and 23:30 if a valid signal is received. Idents are also transmitted during active hours.
Antennas
All the ATV Receive antennas can be rotated to the user direction using the GB3HV Rotator Control
- 23cm RX 15dBd (17dBi) Antec 'Plate' antenna. H polarised.
- 70cm RX 11.5dBd (13.6dBi) 'J-Beam' Multi-beam antenna. H polarised.
The Talkback and DTMF control is vertically polarised. 2m/70cm X-30A Dual Band Collinear. 3dBd/5.5dBd (5.1dBi/7.6dBi)
Transmit antenna: 23cm TX 6dBd (8.1dBi) Antec Omnidirectional 'Plate' Array. [Radiating 50W ERP]. H polarised.
DTMF Control
During operating hours, GB3HV can be DTMF controlled to show a specific input. The DTMF receiver is on 144.75 MHz and the codes are:
*10# Repeater Controller *11# 70 cm Digital Receiver *12# 23 cm Digital Receiver *13# Stream Receiver *14# 23 cm Analogue FM receiver *15# Quad View
*00# Reset to normal operation
Financials
A lot of the rebuild has been made possible by 2 generous BATC grants but going forward we will looking for a small annual subscription (currently £20) to cover the costs (including power) of operating at Roy’s. Please contact the Treasurer, Justin G8YTZ at justin.cockett@me.com
