HAMTV from the ISS
Revision as of 00:08, 22 August 2025 by M0DNY (talk | contribs) (→SDR Hardware)
The original HamTV unit was installed on the ISS in 2013 and commissioned in April 2014 and was used for a number of ARISS school contacts in 2016 - 2018. The unit failed in 2019, and was brought back to earth for repair. It was returned to the ISS on the SpaceX SpX-30 flight on March 21st 2024. Unfortunately a lengthy "topology reassessment" was then required due to space issues in the Columbus module.
29th July 2025 - Following years of work by the ARISS team, the HamTV module has been successfully reinstalled and is active. No video source is currently connected so only a black screen is transmitted.
Reports from stations receiving HamTV, including details of their stations, are on the BATC forum: https://forum.batc.org.uk/viewtopic.php?f=117&t=9197
You can see live video from the ISS as received by a chain of stations using the BATC merger here https://live.ariss.org/hamtv/
HAMTV specifications
Ham Video RF Transmission
  • 2369 MHz
  • 2422 MHz
  • 2437 MHz
Polarisation is RHCP.
DVB-S modulation
  • FEC : ½
  • Rolloff: 35%
TS format
  • MPEG-2 Video, approx. 1.5 Mbits/s, PID 256
  • MP2 Audio, approx 64kb/s, PID 257
  • Null padding, PID 8191
  • NTSC
ISS HAMTV antenna
The HamTV transmission runs relatively low power on 2395MHz to antenna 41 on the ISS which is a simple patch antenna.
What is HAMTV used for?
It is hoped in the future that test patterns, including JPEG images, will be transmitted when the cameras are not in use.
How to receive HAMTV?
* The LNA / Downconverter should placed as close as possible to the dish feed and high quality microwave cable must be used.
* The upper blue-boxes option is the preferred solution for new builders.
* In the blue-boxes option the line amplifier and filters are at 2.4Ghz and GOOD (not cheap) quality satellite co-ax must be used to avoid the RF level being too low at the receiver.
* The satellite line amplifiers are required to ensure there is enough signal at the receiver input - these may be placed at masthead or in the shack
* The filters are essential, not nice to have!
* The Minitiouner V2 / Pico tuner USB receiver can be connected to EITHER a PC running OpenTuner or Minitiouner software or a Pi4 based Ryde set top box receiver.
Ground station antennas
Rotator (mechanical tracking)
  • 1m dish: 8 degrees beamwidth (+/-4 degrees)
  • 1.8m dish: 4.5 degrees beamwidth (+/-2.2 degrees)
Dish feeds
LNA and Pre-amp
A low noise pre-amp (LNA) should be connected directly to the antenna feed point via very high quality feeder to minimise losses. A good LNA should have noise figure (NF) less than 1db and a gain of at least 15 dB.
Commercial LNA Options
Note that very high gain units such as the Kuhne LNAs (60dB gain) can be easily overloaded by WiFi and other RFI without a filter placed in front, which will reduce their performance.
Band pass Filter
Note that 2395MHz is only 5MHz below the 2.4GHz WiFi Channel 1, so good filtering is essential to prevent strong, local WiFi signals from getting into the wide band satellite tuner and causing interference or de-sense. Phil M0DNY has a video on Youtube showing just how much stronger wi-fi can be than the HAMTV signal: https://www.youtube.com/watch?v=ZFvXjWo-MoY
July 2025 update - UK stations are reporting that 4G cellular signals in the 2350 to 2390MHz band are VERY strong and causing issues receiving HamTV.  This makes a good channel filter with maximum 6 MHz bandwidth even more important to receive HamTV.
Receive co-ax cable
Receive Line amplifier
Your masthead LNA/LNB MUST have enough gain to overcome your co-ax cable loss.  The satellite line amplifier can be placed at masthead if needed to help overcome the feeder loss or in the shack.  To hear more about the importance of noise figure and gain distribution in a DATV receive system watch https://youtu.be/lfSi7vTQK44?si=wn_wLBjxco3_RnAf
Do I need a downconverter?
The HAMTV frequency on 2395MHz is outside the frequency range of a standard consumer set top box DVB receiver, and the more affordable SDR receivers and so may require a frequency downconverter. Placing a downconverter at the masthead also allows lower grade coax cable to be used to bring the IF signal back to the shack.
For the BATC Minitiouner DVB receivers, the Mark 2 or Picotuner equipped with the Serit 4434 NIM can tune up to 2450MHz so does not require a downconverter. It may still be useful to use one to reduce loss stations with on long coax feeders. For earlier Minitiouners (using the Sharp or Eardatek tuner) or other DVB receivers you will need a downconverter to place the HAMTV signal between 950 and 2150MHz.
Most downconverters will still require an LNA in front to receive the weak HamTV signals.
For hardware it is often possible to find suitable used "S-band" downconverters from manufacturers such as California Microwave.
On the market products such as Nooelec's "Ham It Down" are also likely to be suitable - but you need to check the output frequency and IF power level, to ensure compatibility with your receiver.
Receivers for HAMTV
The HamTV transmissions can be received using a DVB-S receiver capable of decoding 2 Megasymbol / second MPEG2 transmission. This means that a standard consumer Set Top Box (STB) can be used. However, because the signal is only available during the ISS pass it is essential to use a receiver that can be set to both the frequency and symbol rate before the pass.
Receivers designed for DATV
USB Receiver hardware
Note from 2024 the MiniTiouner has been replaced with the PicoTuner see below.
Mark 2 MiniTiouner PCB
PicoTuner PCB
MiniTiouner Mk1 PCB
NB there is currently no software for Apple macOS to run the Minitiouner USB receivers.
Ryde
OpenTuner
For general details see this wiki page: OpenTuner
Instructions on how to set OpenTuner up for receiving HamTV (updated 30 July 2025) are here: OpenTuner for HamTV
Portsdown
MiniTiouner
SDR (Software-Defined Radio) Receivers
An SDR receiver with a sample rate of >= 2.4Msps (>= 2.4Mhz bandwidth) can be used with a software demodulator to receive and decode the HamTV DVB-S signal.
This solution will require a reasonably powerful PC/Laptop.
SDR Hardware
Cheaper receivers tend to have less dynamic range, this means that they will be very sensitive to the correct RF input levels, and will easily degrade in the presence of RFI such as WiFi and Cellular signals. More expensive SDR receivers tend to be better but can easily exceed the cost of the hardware DVB receivers above.
In order of increasing cost:
  • RTL-SDR - works but not recommended for reliable reception, the limited dynamic range is easily impacted by RFI.
  • Airspy SDR
  • ADALM-PLUTO PlutoSDR
  • HackRF One
  • Lime Microsystems LimeSDR
  • Ettus USRP
SDR Software
SDRTV by Simon Brown G4ELI will NOT receive the DVB-S HAMTV signal and the author has confirmed the capability will NOT be added to any future release.
Receiving the Signal
Testing your system
Measuring sun noise
Portsdown DATV test system
  • Connect the signal from your LNA / downconverter to the rx port on a Lime SDR or a Pluto SDR and select Menu 2 > test equipment > Noise power meter.
  • In setting menu, adjust the Lime gain so that the noise floor sits at around -60dBm.
  • From the main menu, select differential in the mode settings and then touch the right side of the "analogue" meter display on the main menu to set it to display -5 to +5dB.
  • As you turn your antenna through the sun you should see a hump on the the time / gain display as the meter reads the level of sun noise - expect to see approximately 2dB on an average HamTV system.
The Portsdown DATV transceiver has a number of very useful RF test modes including a noise figure meter and a noise power meter.  A very simple system can be built from a Raspberry Pi 4 running the free to download software and a LimeSDR or Pluto SDR - see this wiki page for a complete list
SDR continuum mode
Decoding a local signal
Playing out a local IQ file
  • Connect the Portsdown to the internet and attach a LimeSDR. On Menu 1, select "Freq" and select the frequency that you want the signal to be generated on; you can use the keyboard key to enter 2395 MHz.
  • Select Menu 2, File Menu, Download HamTV IQ File. Note that this is a 2 GB file which takes at least 5 minutes to download, and another 5 minutes to unzip.
  • Once the file has downloaded, select Menu 2, File Menu again and then "Select IQ File". Touch the file SDRSharp_20160423_121611Z_731000000Hz_IQ.wav so that it is highlighted and press select.
  • Then press "Play IQ File". The file will be played out on the frequency that you selected in the first step.
  • 5Ms/s Complex Samples
  • WAV (SDRsharp) format
  • Please note that these were recorded on a 0.6m hand-steered dish, so the signal in the recordings will fade in and out of being decodable even with the best receiver!
Actually receiving HamTV
Social media
BATC forum
Youtube videos
Comments on this wiki page
