Using LimeSDR with Portsdown
Revision as of 09:22, 13 January 2019 by G8GTZ (talk | contribs)
With the Portsdown Filter Modulator board being discontinued (Jan 2019 - no further FM boards will be available after the current shop stock is sold) it is envisaged the LimeSDR Mini will become the standard modulator for use with the Portsdown system and will be available for purchase in the BATC members shop. More details on the LimeSDR Mini can be found here LimeSDR Mini Information.
The LimeSDR Mini is slightly more expensive than the Portsdown Filter Modulator board but does not require the use of a separate ADf4351 Local Oscillator module and a Local Oscillator filter board. Note - the LimeSDR Mini is available from the BATC members shop at a slightly discounted price compared to the normal retail price from the US plus shipping and 22% import duty charges.
Setting up the system
Either buy a pre-configured SD card from the BATC shop or download and install the standard Portsdown software on your own SD card - see this page for more details: https://wiki.batc.org.uk/Initial_setup
Hardware Installation
Installing the Lime Software
The LimeSuite software version 18.10.0 (Build 2018-12-28, Interface version v2018.10.0, Binary Interface 18.10-1) is loaded as part of the normal Portsdown build and update process. This may not be the latest version, but is compatible with other components of the Portsdown software and DATV Express V1.25lp12.
Lime Configuration Menu
The "Update Lime FW" button updates the Lime SDR firmware and gateware to the appropriate version for the installed LimeSuite. For Portsdown software versions 201811300 and later, the correct versions are shown below. You should see the same screen after selecting "Lime FW Info". Note that BATC Shop LimeSDR Minis may display Hardware Version 2, and Gateware version 26 - this is being investigated.
The LimeSDR Minis purchased from the BATC shop are a later hardware version than described above. On delivery, the Lime FW Info is as below:
For use with the Portsdown (and DATV Express 1.25lp12) you should upgrade the firmware to the latest version for the best results. Then the Lime FW Info will report:
If you do not upgrade the LimeSDR, the transmitted spectrum will not be as clean. If you are unable to upgrade due to apparent problems with the Portsdown/LimeSDR combination, please report the details on the BATC forum.
Transmitting
Limitations
System Diagram
Acknowledgements
