Portsdown hardware
This section of the user guide describes all the hardware modules and interconnections required to build the Portsdown 2019 DATV system.
Each component that you need is described in more detail here. Suggested suppliers for each item are listed underneath the description in the quote box.
Raspberry Pi 3
The first item required is a standard Raspberry Pi 3 or 3+. These are available from many suppliers but we suggest you just buy a vanilla Rpi3 without additional boards or SD cards as you will be using specific Portsdown hardware and software.
Raspberry Pi 3: CPC Farnell http://cpc.farnell.com/mksp2-raspberry-pi
Power Supplies
You should power the RPi through the Micro-USB power connector to take advantage of the input protection provided. Use a very short USB cable to your power supply as most of these cables are of very poor quality and cause significant voltage drop. If you see a "Lightning Flash" symbol at the top right of your LCD display it means that the voltage at the RPi is too low. You can measure the voltage between the GPIO connector pins 4 and 6.
A lot of strange problems, such as the Portsdown running very slowly, can be caused by poor PSU volts - the Rpi3 is actually specced for 5.1 volts, make sure your PSU delivers enough volts and current. See this post on the BATC forum for a real user experience!
You will also need a 12 volt DC supply to power the other Portsdown components.
Micro-SD Card
The easiest way is to buy a pre-programmed SD Card from the BATC shop. (Item 2 in the Portsdown list).
OR if you want to have a go at loading the software yourself you will need to or purchase a good quality card from another source and follow the instructions described here. (The 16GB SanDisk Ultra is recommended - DO NOT use cheap copies)
SanDisk Ultra 16 GB Micro-SD Card: Amazon https://www.amazon.co.uk/s/?ie=UTF8&keywords=micro+sd+16gb+ultra
Once you have a card you will need to follow the initial set up guide
This is the minimum hardware configuration you need for testing the Portsdown transmitter! You can use an external PC to control the Portsdown in Console mode and run the QPSKRF or Ugly test mode using moving test patterns and images. (But as "ugly mode" only runs in reduced bandwidth or RB-TV mode, you will need a MiniTiouner to receive it.)
To use your Portsdown as a "proper" DATV transmitter you need the following components:
LCD TouchScreen
The touchscreen is required to control the transmitter without the use of another computer. The supported touchscreen is a 3.5 inch diagonal Waveshare Raspberry Pi LCD (Model A, not Model B). This is available from a number of suppliers for under £20. It uses a resistive touch panel and has a resolution of 480*320.
If you do want a larger touchscreen, the 7 inch Element 14 touchscreen https://www.element14.com/community/docs/DOC-78156/l/raspberry-pi-7-touchscreen-display is now supported. Also available from Amazon: https://www.amazon.co.uk/Raspberry-Pi-7-Inch-Screen-Display/dp/B014WKCFR4
Get the Waveshare display from Amazon: https://www.amazon.co.uk/Waveshare-Raspberry-Resistive-Interface-Rapsberry-pi/dp/B00OZLG2YS or several suppliers on ebay.
To mount the screen away from the RPi, you could use this extension cable: https://thepihut.com/products/adafruit-gpio-extender-cable-for-raspberry-pi-model-a-b-26pin-12-long Just make sure that you triple-check the connections and pin orientation before connecting the screen. They do not tolerate incorrect connection as several of us have found out! Alternatively, you can make one yourself from a discarded 3.5 inch floppy drive and its lead.
Touchscreen mount
Mounting the LCD Touchscreen can be a challenge!
This 3D print design mounts it flat to the panel: https://www.thingiverse.com/thing:1941701
This 3D print design mounts it at an angle: https://www.thingiverse.com/thing:1920486.
GPIO Extender Card
In the completed unit, there are 13 signals that need to be routed in or out of the GPIO interface on the RPi. Plus we need to break out all 40 pins of the GPIO, and have another connector on top for the LCD display. Because of this the Portsdown team have designed a PCB for the job - the blank PCB for this is available from the BATC shop.
LimeSDR Mini
The Portsdown 2019 system uses the LimeSDR Mini to provide the modulator and RF generator functions. It is more flexible than the previous custom built FM board in that it will do DVB-S2 and has much greater frequency coverage.
The LimeSDR Mini is available from the BATC shop https://batc.org.uk/shop/limesdr-mini/ - the LimeSDR Mini is similar in cost to the FM board as you no longer need an ADF4351 LO module and an LO filter PCB.
You now have the components for a fully working Portsdown transmitter! See this page for suggestions on how to connect it all up.
Raspberry Pi Camera
To help make sure you buy a unit that will work with Portsdown we are now stocking the Fushicai USBTV007 Audio-Video Grabber which is guaranteed to work in the BATC shop - item 11. More information on the device can be found here.
Audio Capture Device
Audio Capture Device: Source from eBay - for example: http://www.ebay.co.uk/sch/Laptop-Desktop-Accessories/31530/i.html?_from=R40&_nkw=usb%20audio%20adapter&_dcat=75518&Channels=2%252E0&rt=nc&_trksid=p2045573.m1684
However, the team has design some additional components to enable you to build a complete DATV transmit system
4-Band RF Output Switch
The Portsdown team have developed a 4-Band RF output switch capable of switching the low level output of the LimeSDR Mini to separate amplifiers for the 70, 144, 437 and 1255 MHz bands. Note: due to potential high insertion loss, it is not recommended to use the switch above 23cms.
4-Band Decode Switch
Full details on the board including circuit etc are available here. Blank PCBs are available in the BATC shop - item 5.
8-Band RF Output Switch
For those of you who also want to drive Microwave transverters from your Portsdown 2019 LimeMini SDR, the team have developed an 8-Band RF output switch that includes an RF amplifier. It is designed to be used with the Output Attenuator (see below). It will be capable of amplifying the variable level from the attenuator and switching it to separate amplifiers for the 70, 144, 437 and 1255 MHz bands, and to 4 transverters for the higher bands. PCBs are on order and will be available from the BATC Shop.
Full details including parts list and schematic are available on this wiki page. Blank PCBs are available in the BATC shop - item 9.
8-Band Decoder
This 8-band decoder is designed to work with the 8-band RF output switch and the Portsdown 201 software. It will provide switching signals (either always on, or PTT activated) to 4 Power Amplifiers and 4 transverters, and it also enables you to set which VCO filter should be switched in for the 4 transverter outputs. PCBs are on order and will be available from the BATC Shop.
Full details on the board including circuit etc are available here. Blank PCBs are available in the BATC shop - item 7.
8-Band Decode PIC
This is the pre=programmed PIC to control the custom designed 8 band decode board for the Portsdown 2019 transmitter.
Filters and PA drivers
Hardware shutdown
In order to prevent SD card corruption by just removing the power to shut the system down, it is recommended that you include a shutdown switch.
When the facility is enabled (not by default), Pin 15 on the GPIO port signals the RPi to shutdown cleanly.
It is held low by a pulldown resistor in the RPi; when taken to 3.3v through a pushbutton it will command the RPi to shutdown. The signal on pin 13 can be used to illuminate an LED through a current limiting resistor. This LED illuminates when the RPi is active, and extinguishes when the software has shutdown and it is ready for power-off.
The RPi can be restarted from the "ShutDown" state without recycling the power by momentarily shorting the 2 "RUN" pads that can be found behind the USB Connectors.
Output Attenuator
You can use an electronically switched attenuator to adjust the transmit drive level for each band. Attenuators based on the PE4302, HMC1119 or PE43703 (preferred) are supported.
