Getting Started
Amateur Television is a fascinating area of Amateur Radio covering all aspects of video production, editing, transmission and reception of Television and has always been at the fore front of the technology revolution. Many stations are now transmitting Digital pictures (DATV) using the DVB broadcast standards and using video streaming technologies to exchange pictures with ATV operators around the world.
You're probably here because you want to know more about Amateur Television and so help you get to grips with the basics of our hobby, BATC has put together a series of "Getting started" guides.
Once you've read those, you may be wondering if there's an easy way to "get on the air" - if so take a look at this page which shows you how to join in the fun on 5.6GHz ATV for under £20! Or if you are wondering what what DATV equipment you need to buy, so we have put together a DATV shopping list to help you decide how to spend your hard earned cash!
Digital ATV primer
Receiving DATV
The only real show in town and the most flexible, is the PC based MiniTiouner system with a USB tuner card. The reason for this is that it tunes from 143 MHz to 2450 MHz so covers all the bands from 146 > 13cms and with a standard LNB can be used to receive Oscar 100 signals. It also can recieve all the Symbol Rates (SR) or bandwidths from 33Ks (the lowest RB-TV you will find) right up to 27,500 as used on Freeview etc.
The system consists of the USB tuner card hardware which you build (no Surface Mount!) - the 4 hard to get components are from the BATC shop and the software is free to download - total cost = ~£80 depending upon the case you use.
See https://wiki.batc.org.uk/MiniTioune for more details.
DATV transmit
This basic system will cost ~ £250 ( less than a dual band FM rig!) and give you a full blown DATV transmit system from 50MHz up to 3.4GHz with good picture quality over all the common symbol rates. Again you will need filters and amplifiers for the band of your choice....
[[1]]
A slight confusion now is that you can plug the MiniTiouner USB tuner hardware in to the Portsdown system and it will display the pictures, thereby becoming a full DATV transceiver and replacing the need for a PC.
Getting Started - the basics
DATV Reception
Reduced Bandwidth TV
Video signal basics
What next?
Having read and digested all the information in these getting started guides and want to get on air, the next thing to look at is the BATC Portsdown DATV transmitter project. There's probably someone building one near you - you can check by looking at the Portsdown users map.
