Ryde Receiver
Revision as of 19:18, 13 July 2020 by G8GTZ (talk | contribs) (→Code base)
The BATC Ryde receiver is a stand-alone receiver for Digital Amateur TV with similar functionality to a consumer Set Top Box (STB)
It will be a standalone receiver controlled by an infra-red remote with on screen menus. It will directly drive an external monitor and not require any additional hardware such as a PC.
Project history and status
The Ryde receiver was conceived by G8GTZ and the first requirements published in April 2020 and first beta models were demonstrated in July 2020. An initial development release is expected by the beginning of August 2020
Ryde Hardware
The hardware is described here Ryde Hardware.
Original requirement specification
Outline specification
Code base
Functionality
Network capability
