Ryde Receiver
Revision as of 19:28, 13 July 2020 by G8GTZ (talk | contribs)
The BATC Ryde receiver is a stand-alone receiver for Digital Amateur TV with similar functionality to a consumer Set Top Box (STB)
It will be a standalone receiver controlled by an infra-red remote with on screen menus. It will directly drive an external monitor and not require any additional hardware such as a PC. It will provide a lock indication output for use at DATV repeater sites.
Project history and status
The Ryde receiver project was conceived by G8GTZ, the first requirements were published in April 2020 and first beta models were demonstrated in July 2020. An initial development release is expected by the beginning of August 2020
Ryde Hardware
The hardware is described here Ryde Hardware.
Outline specification
Code base
Functionality
Network capability
