Ryde Receiver
Revision as of 07:58, 15 July 2020 by G8GTZ (talk | contribs)
The BATC Ryde receiver is a stand-alone receiver for Digital Amateur TV with similar functionality to a consumer Set Top Box (STB) but with a "point and shoot" interface - simply enter frequency and SR and the Ryde with look for signals without the need to scan across a range a frequencies.
  • The Ryde is a standalone receiver controlled by an infra-red remote with on screen menus.
  • The Ryde directly drive a composite or HDMI external monitor
  • The Ryde does not require any additional hardware such as a PC.
  • The Ryde will provide a lock indication output for use at DATV repeater sites.
Project history and status
The Ryde receiver project was conceived by G8GTZ, the requirements were published in April 2020 and first beta models were demonstrated in July 2020. An initial development release is expected by the beginning of August 2020
Ryde Hardware
The Ryde hardware is described here Ryde Hardware.
Ryde repeater receiver
As well as a dedicated shack receiver without the need for a PC, the Ryde is also designed for use at repeater sites. Features in the requirement specification p include the following (all subject to feasibility and commitment by development team volunteers):
  • Reliable lock indicator output from the Rpi GPIO connector.
  • Status banner displayed with GPIO port triggered (can be triggered by external DTMF detector etc)
  • Symbol rate search across a number of presets. Enables one Ryde to listen on 437 and receive 2Ms, 1Ms, 333ks and 125ks signals
Outline specification
Code base
Functionality
Network capability
