Ryde Receiver
The BATC Ryde receiver is a stand-alone receiver for Digital Amateur TV with similar functionality to a consumer Set Top Box (STB) but with a "point and shoot" interface - simply enter frequency and SR and the Ryde will look for DATV signals without the need to scan across a range a frequencies.
  • The Ryde is a standalone receiver controlled by an infra-red remote with on screen menus.
  • The Ryde directly drive a composite or HDMI external monitor
  • The Ryde does not require any additional hardware such as a PC.
  • The Ryde will provide a lock indication output for use at DATV repeater sites.
Project history and status
The Ryde receiver project was conceived by G8GTZ, the requirements were published in April 2020 and first beta models were demonstrated in July 2020. An initial development release is expected by the beginning of August 2020
Ryde Hardware
The first version of Ryde is based around a Raspberry Pi 4 and the BATC MiniTiouner V2 PCB connected via USB. A single PCB may be developed in future removing the need for the USB interface.
The hardware is described on this page Ryde Hardware.
Ryde repeater receiver
  • Reliable lock indicator output from the Rpi GPIO connector.
  • Symbol rate search across a number of presets. Feature would enable a single Ryde receiver to listen on 437 and receive 2Ms, 1Ms, 333ks and 125ks signals
Outline specification
Code base
Functionality
Network capability
