Ryde Receiver
The BATC Ryde receiver is a stand-alone receiver for Digital Amateur TV with similar functionality to a consumer Set Top Box (STB) but with a "point and shoot" interface - simply enter frequency and SR and the Ryde will look for DATV signals without the need to enter Bouquets, transponders or scan across a range a frequencies.
- The Ryde will (in a future build) provide a lock indication output for use at DATV repeater sites.
Project history and status
The Ryde receiver project was conceived by G8GTZ, the requirements were published in April 2020 and first beta models were demonstrated in July 2020. An initial development release is expected by the beginning of August 2020
Ryde Hardware
The first version of Ryde is based around a Raspberry Pi 4 and the BATC MiniTiouner V2 PCB connected via USB. A single PCB may be developed in future removing the need for the USB interface.
The hardware is described on this page: Ryde Hardware.
More details on which remote control to use are here: Ryde remote controls
Ryde repeater receiver
Outline specification
Code base
Functionality
Network capability
