Ryde Receiver
Revision as of 16:20, 29 August 2020 by G8GTZ (talk | contribs)
Project history and status
Ryde Hardware
The hardware, including details on the RPi GPIO connections needed, are described on this page: Ryde Hardware.
Version 1
Version 2
IR remote control
Ryde Software
  • LongMynd. A specific version of LongMynd is used to control the MiniTiouner.
  • RydePlayer. RydePlayer controls LongMynd, responds to remote control commands, manages the on-screen menus and controls the VLC video player.
  • Pydispmanx. Pydispmanx is a utility to manage the layers (overlays) on the display.
  • Ryde-Build. Ryde-build provides an installer, updater, console menu and currently manages selection of remote controls and display output.
The currently the only way to install the Ryde software is to build an SD Card and then install the software using the instructions here: BATC GitHub Ryde Build Page. The process will be familiar to anyone who has built a Portsdown SD Card.
Please read this information about the Ryde Software.
Ryde repeater receiver
Outline specification
Code base
Functionality
Network capability
