Portsdown 4
Revision as of 08:47, 11 September 2020 by G8GTZ (talk | contribs) (→More information)
Capabilities
The software build is also compatible with the Langstone Microwave transceiver software, which can be loaded by from touchscreen selections (menu 2) AFTER the Portsdown software has been installed. To operate, the Langstone software needs a Pluto to be connected by USB, and a compatible USB Audio dongle.
The build is on GitHub at https://github.com/BritishAmateurTelevisionClub/portsdown4
Pluto Capabilities
The Pluto mode is experimental at present and is described here Portsdown 4 Pluto.
FAQ
cd /home/pi
chmod +x /home/pi/update.sh
./update.sh
More information
