Portsdown 4
Revision as of 14:34, 28 November 2020 by G8GTZ (talk | contribs) (→‎Software)
Capabilities
  • Control of a Pluto, DATV Express, ADF4351 and Elcom Microwave Source using the Portsdown 4 Signal Generator.
Powering the Pluto
Pluto Capabilities
The Pluto mode is experimental at present and is described here Portsdown 4 Pluto.
FAQ
cd /home/pi
chmod +x /home/pi/update.sh
./update.sh
More information
