Portsdown 4
Revision as of 14:36, 28 November 2020 by G8GTZ (talk | contribs) (→Hardware)
Capabilities
  • Control of a Pluto, DATV Express, ADF4351 and Elcom Microwave Source using the Portsdown 4 Signal Generator.
Portsdown 4 GPIO connections
Due to a reassignment of the GPIO pins on Portsdown 4, the connections are different to previous generations of Portsdown.
Powering the Pluto
Pluto Capabilities
The Pluto mode is experimental at present and is described here Portsdown 4 Pluto.
FAQ
cd /home/pi
chmod +x /home/pi/update.sh
./update.sh
More information
